Old 04-13-2014, 08:22 PM   #1
87squarebody
87squarebody's Avatar
Parts needed off of donor truck for 6.0 swap
I would like to know do I need the big fuse box panel that is located under the hood for my swap.Also do i need any of the harness that goes inside the truck or hidden sensors or switches.It is a drive by cable throttle.Do in keep the throttle cable from donor truck for my 87.Thanks in advance.
87squarebody is offline   Reply With Quote
Old 04-14-2014, 12:30 PM   #2
stroker87
Re: Parts needed off of donor truck for 6.0 swap
the wires that go inside the cab should mostly be for the gauges and the VAT system, I'm not sure about the fuse block I would think you dont but cant say for sure?
not sure if I'll get in trouble for this but you might fine your answer here http://lt1swap.com
stroker87 is offline   Reply With Quote
Old 04-14-2014, 12:57 PM   #3
nekkidhillbilly
http://ls1tech.com/forums/conversions-hybrids-28/
search here
2004 2500 hd dmax cc 4x4
2008 saturn aura xr
1966 buick gran sport
1984 k20
nekkidhillbilly is offline   Reply With Quote
Old 04-14-2014, 01:01 PM   #4
nekkidhillbilly
you def need the pedal and pedal harness.
2008 saturn aura xr
1984 k20
Old 04-14-2014, 02:39 PM   #5
Jonboy
Slots go on anything!
I would grab the pedal just in case, but you definitely want the cable. I would try to get everything you possibly can. You can always pitch what you don't end up using.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 04-14-2014, 02:57 PM   #6
nekkidhillbilly
is it cable thottle then all you need is the cable.
2008 saturn aura xr
1984 k20
