Old 11-12-2019, 07:28 PM   #1
Electro72
1970 GMC front parking light socket/pigtail
Any one know where I can get the socket/pigtail for the front parking lights on a 1970 GMC?
Electro72 is offline   Reply With Quote
Old 11-12-2019, 11:23 PM   #2
kaycee
kaycee's Avatar
Re: 1970 GMC front parking light socket/pigtail
iNAPA or you might you might try the TRUCK SHOP in Orange County
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 11-12-2019, 11:23 PM   #3
vitamin_c95
Classic industries and brothers is close by to you
1971 C20 Longhorn 350/350 "Conquistador"
vitamin_c95 is offline   Reply With Quote
Old 11-13-2019, 10:00 AM   #4
Are you guys saying you know these places have this model specific part? If anyone offers them I don't know about it. If they are available I'd like to know. I hang on to any used ones I find. I have lamps that need them.
Old 11-13-2019, 11:41 AM   #5
Electro72
This is not a Want To Buy thread. Thanks
Old 11-13-2019, 02:53 PM   #6
HO455
HO455's Avatar
I cannot speak specifically to the GMC signal in question, but if I were to guess it is similar in construction to the one in this thread. You may find the answer you are looking for here.
http://67-72chevytrucks.com/vboard/s...d.php?t=796218
Here is a different way to solve the problem.
http://67-72chevytrucks.com/vboard/s...d.php?t=750570
Good luck
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
Old 11-13-2019, 04:14 PM   #7
Montierth
Montierth's Avatar
I have seen them on ebay used. I had a parts truck that I stole them from. Before I got them off my parts truck I could not find them in reproduction. I did find a light socket at Autozone that I wired myself that fit the parking light socket as a temporary solution. Wasn't pretty but it worked and nobody could see it.
1970 GMC C1500 short fleet
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 1970 GMC C2500 Dually Flat Bed
- 2003 Silverado
Montierth is offline   Reply With Quote
Old 11-13-2019, 04:21 PM   #8
Montierth
Montierth's Avatar
What I used -
JT&T (2570F) 2-WIRE UNIVERSAL DOUBLE CONTACT PARK, STOP, TAIL & TURN LIGHT SOCKET PIGTAIL, 1963 - 1977, 1 PC.
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 2003 Silverado
Old 11-16-2019, 10:50 PM   #9
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 1970 GMC front parking light socket/pigtail
OK so I have been working on my daughters 68 truck getting it tore down. I took the grille apart and pulled the front parking lamps off. They are basicly the same thing as your bumper lights just mounted in the grille.
So any way I decided to check them and see if they worked. One did the other one wouldn't hooked to my battery. I used a jumper wire to the pigtail and another one to the mounting bolt. Nothing. Took the bulb out and checked it. Broke the bulbs both trying to get them out.
So I got to looking inside the socket. The double wire insert was stuck in the bottom no springing action. I soaked it down good with PB blaster and used a small screw driver. I could push down but it wouldn't spring back up. I cut the rubber right at the housing on the back side and used the small screw driver to punch it up. I worked it back and forth until it would spring back on it's own. I will tape the rubber back down to the housing but I got it working. Both lights work fine now. Hope this helps you on yours it may just need a little push.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-17-2019, 07:14 PM   #10
Andy4639
Old member
Andy4639's Avatar
Here are some simple easy way's to check your lights and fixtures to make sure they work once installed in the truck. This will work on just about any GM vehicle made as long as it's 2 wires in the harness.
I just want to say I'm not a video expert. I just try to help people best I know how.
First video is making sure you get the proper fitting of the bulb inside the socket.
https://www.youtube.com/watch?v=-WG6hKt6OGQ
These video show how to use a 110AC input/12 volt output plug in.
https://www.youtube.com/watch?v=WQu005yAQ24
Old 11-17-2019, 10:44 PM   #11
Montierth
Montierth's Avatar
Any luck finding the socket?
Sellers Regret
- 1950 GMC
- 1967 Chevy C10
- 2003 Silverado
Old 11-18-2019, 04:56 PM   #12
MARKDTN
Originally Posted by Montierth View Post
What I used -
I have bought these and taken the wires out. You can re-use what isn't broken from your original and save splicing wires sometimes.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
