Old 04-13-2019, 11:41 AM   #476
Metaldoc
Metaldoc's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by NewBayColony View Post
Keep us up to date on this. What are you using for a head unit?
The small blue unit is my FM radio, blue tooth, sd card, usb, and 1/8" jack. It has uhf remote so I don't need to point the remote like infrared.
Do it, Do it right, Do it right the first time
Metaldoc is offline   Reply With Quote
Old 04-13-2019, 07:18 PM   #477
70STOVEBOLT
70STOVEBOLT's Avatar
Got the front part of the frame cleaned and painted. First coat, still need to remove the steering box and idler arm and paint behind them.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Coming soon: EFI
2015 Silverado 1500 LS 4.3/6L80/3.23
70STOVEBOLT is offline   Reply With Quote
Old 04-13-2019, 08:00 PM   #478
External
External's Avatar
After putting the shroud and fan on and taking it off at least 5 times...
I finally got my truck upgraded to a fan clutch, closed coolant system, new 6 bladed fan, new raidaitor with new hoses and clamps! Also learned how to bend some new transmission cooling lines. Easier than I expected.
Very excited to put it all back together.
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning!
External is offline   Reply With Quote
Old 04-14-2019, 12:06 AM   #479
NoStopN
NoStopN's Avatar
I'm afraid we're going to need more than just "the small blue unit". Even zooming in I can't read the brand name on it.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline   Reply With Quote
Old 04-14-2019, 09:18 PM   #480
Linkman440
Finally got my grille guard installed
Linkman440 is offline   Reply With Quote
Old 04-14-2019, 09:23 PM   #481
rjs53
Finished the door seals and window felts, put door panels on and got the dash painted and put back together. Next week windshield and alignment.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 04-14-2019, 09:55 PM   #482
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Painted some stuff, and rebuilt the rag joint. The parts are original less the disc, pins, sleeve nut and wave washer that came in a kit. The coupler and flanges are ceramic coated
Some gibberish, kind of cloudy. I take a lot of notes, though this little project called for captions. Took me a little while to figure it out, cuz I'm slow
Might help others build one. Doubt I'll ever build another, but who knows. Glad to have rebuilt this as opposed new. The old parts are nice. On a side, I used blue thread locker on their nut where the kit calls for a lock washer. Lock washer don't fit.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-15-2019, 12:45 AM   #483
Metaldoc
Metaldoc's Avatar
They're made for motorcycles, I got it off Amazon. The new ones have blue tooth built in, I use a small adapter.
Old 04-15-2019, 12:51 AM   #484
Metaldoc
Metaldoc's Avatar
Working on installing some new front speakers, made a new bracket and think about what I did with the old speaker screw. It pays to be organized, it was blasted, painted and stowed in the bag marked dash.
Old 04-17-2019, 06:42 PM   #485
RodnRudy
RodnRudy's Avatar
I made some progress buttoning up the rebuilt engine for Old Red. All I have to do is put on the exhaust manifolds and it's ready to plunk down in the engine bay. I went ahead and primed the oil and set the distributor in on #1 so I won't have to crawl in the engine compartment to do that.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 04-17-2019, 09:04 PM   #486
NewBayColony
NewBayColony's Avatar
Can you yank the engine without taking the hood off in these? I have to pull mine this year and I just assumed you did have to take the hood off.
72 C20 292 3OTT
77 GMC 2500 4x4 Longstepper 350 4sp
50 3100 ex Airforce/Town of Mendon fire truck
72 GMC 1500 2wd short stepside 250 4sp
78 GMC 2500 4x Longstepper 292 4sp
54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman)
NewBayColony is offline   Reply With Quote
Old 04-17-2019, 10:26 PM   #487
RodnRudy
RodnRudy's Avatar
Yes I was able to remove the engine with the hood on. I lifted it up and forward and then rotated it so the distributor would not hit the hood and then lifted it enough for the oil pan to clear the core support. It's close but it came out.
Phil
Old 04-18-2019, 05:09 AM   #488
Blue18
3 inch lowering spring and 2 inch block in the rear. New bilstein shocks and adjustable panhard bar!!!
Blue18 is offline   Reply With Quote
Old 04-18-2019, 11:05 AM   #489
OregonNed
OregonNed's Avatar
I did some web research and ordered new inner door panels that will be arriving today. It was a bit of a wait for them to be customized. Will post pictures when I get them in.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 04-18-2019, 09:37 PM   #490
Thrill4130
Active Member
Thrill4130's Avatar
I got my camper on and bolted up last night. I made some mounts for stake pockets. Needs a back door , insulation and couple other things but it’s on.
Thrill4130 is offline   Reply With Quote
Old 04-18-2019, 10:59 PM   #491
3757chevy
3757chevy's Avatar
looking good, I like your pocket mounts.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 04-20-2019, 10:28 PM   #492
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
I bored out 67 wiper knobs to 1/4" and added some aluminum tape to simulate deluxe knobs. Added the knobs to my under dash A/C unit. Fabbed up some brackets and installed the under dash unit.
http://67-72chevytrucks.com/vboard/a...1&d=1555813380
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is online now   Reply With Quote
Old 04-21-2019, 08:58 AM   #493
zicc1835
zicc1835's Avatar
very nice
zicc1835 is offline   Reply With Quote
Old 04-21-2019, 09:01 AM   #494
zicc1835
zicc1835's Avatar
I cant tell from the pictures is your exhaust tucked up in the frame ?
Old 04-21-2019, 06:59 PM   #495
Redneck Rydes
Redneck Rydes's Avatar
I put a 1 1/4 front sway bar on my truck today,also pulled my gas tank,had a annoying vibration when tank was full, must have had no deadner behind it,put some glued on deadner on the back of the cab,reinstalled tank,and good to go,brought in the 85 c10, gonna go over it and get ot ready for a safety check and put it on the road.
Redneck Rydes is offline   Reply With Quote
Old 04-21-2019, 08:28 PM   #496
67_C-30
I have a radical idea!
67_C-30's Avatar
Sanded and painted my 6” steelies for the front and waiting on the 8’s to get back from sandblasting to put my “new” ‘72 on steelies.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 04-21-2019, 09:40 PM   #497
Metaldoc
Metaldoc's Avatar
The vibration may be from pinion angle under the weight of a full tank. Ya may need shims in the mounts.
Old 04-22-2019, 11:06 AM   #498
70STOVEBOLT
Yes. I don't have a pic from the side but it is approximately even with the bottom of the frame rail, you can see the headers a little bit though.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Coming soon: EFI
Old 04-22-2019, 11:46 AM   #499
gmc1969custom
Put some on new Tires and painted my steels a nice bright white.
1969 Custom w/Turquoise Interior. 75k miles, 350 Auto, (Almost) All Original
gmc1969custom is offline   Reply With Quote
Old 04-22-2019, 02:29 PM   #500
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Nice engine. Is that roller rockers on it and where did you get the valve covers, I like them.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
