07-28-2020, 08:41 AM | #1 |
Still Green but learning
change my own windshield?
Hi, how hard is it to change my own windshield glass (71 C10)? I have called Safelite but have a feeling its going to be pricey. I can get the glass in from summit or jeggs, both with great reviews. but not sure if its something I want to tackle. Gonna find videos on it at some point but thought i would ask here first.
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
07-28-2020, 08:49 AM | #2 |
Re: change my own windshield?
You can do it, although it would be much easier with a helper or two. A new gasket makes things much simpler - the Precision gaskets seem to be the best. If you have trim make sure you get the gasket for the right year - there's a difference in trim depth.
Put the gasket onto the windshield and wrap a piece of 1/4" braided nylon rope into the pinchweld slot all around the gasket - it should cross at the top. Next comes the trim - put it in and use some masking tape to hold it in place. Now you're ready to put in the windshield. This is where the helpers come in, because you're going to start installing the windshield from the top. It's one of only two I know of that are best done this way - the other was the old Jeep Wagoneer. You want to make sure you get those top corners in, and just pull the rope gently while your helpers push the glass against the pinchweld. Glass cleaner works well as a lubricant, and it's much easier to clean up than soapy water.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
07-28-2020, 09:58 AM | #3 | |
07-28-2020, 10:08 AM | #4 |
I did it by myself. Don't recommend it. Get at least 1 helper, 2 might be even better. Yes it is doable. Just watch a couple of videos and take your time.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
07-28-2020, 10:39 AM | #5 | |
07-28-2020, 02:00 PM | #6 | |
But if you can get it installed for $100 more, I'd go that route, because they assume the liability. Look for someone that has experience in classic vehicles - most Safelite installers don't.
07-28-2020, 02:37 PM | #7 |
I think it’s worth pointing out that there are quite a few posts on this board telling stories about professional windshield installers who just can’t seem to get it right no matter how hard they try. Several members have just walked away from the pros and found another installer or taken matters into their own hands. Even though you’ve transferred the obligation to a 3rd party by hiring a pro, this doesn’t ensure success.
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
07-28-2020, 02:49 PM | #8 | |
Thanks all!
07-28-2020, 03:11 PM | #9 | |
07-28-2020, 10:12 AM | #10 |
Moderator
Precision has videos on doing your exact windshield.
07-28-2020, 10:22 AM | #11 |
Let the rubber sit in the sun for a while makes it easier to work with . We used silicone spray as lube. Just wipes off with a hand cleaning wipe.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
07-28-2020, 10:22 AM | #12 |
The Older Generation
If you have never done it before I would recommend at least 3 people - 2 on the outside and one 1 on the inside. LockDoc
07-28-2020, 10:31 AM | #13 |
I second this
07-28-2020, 10:43 AM | #14 | |
They started the rope pulls at the bottom, but I convinced them to start at the top for the rear glass as they were having trouble with the trim popping out at the top corners...that seemed to help, but the front glass was started at the bottom. The outside looks good, but the inside at the top corners has some gaps...starting at the top might of helped this...IDK. They only charged me $216...they supplied the front glass and I supplied the rear slider, Precision gaskets, and OEM trim.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
07-28-2020, 10:38 AM | #15 |
So safelite is quoting me 437.65, installed.
Summit/Jeggs windshield and prec. gasket is 326.34 shipped. For 100.00 getting someone else to be responsible for it and get warranty on the work seems like a decent deal.... thoughts?
07-28-2020, 10:53 AM | #16 |
Having a beer on a patio while two or three other guys sweat it out sounds just about right to me. Money well spent. Save your skills for something else. Have a good one eh.
07-28-2020, 10:59 AM | #17 |
For only a $100 more, have someone else do it. Just make sure the warranty their work and are responsible for any damage, such as breaking the windshield. In writing!
07-28-2020, 11:11 AM | #18 |
Are you in a larger area that seems like a high price to me
I picked up a new winsheild for my 72 from the glass wholesaler for 80 bucks I got glass for a 08 van 92 c1500 00 Corolla and 72 k10 for 326 cad Local glass shop quoted 500 for install new winsheild in corolla |
07-28-2020, 11:28 AM | #19 | |
07-28-2020, 12:24 PM | #20 |
My wife and I installed the back window and the windshield of my ‘68, with stainless trim. It was my first fixed glass installation. The back window went fine and the windshield took three tries to get it right. Haven’t followed up with sealer In the corners yet, as is recommended. I bought Precision gaskets and followed the Precision installation video. I found that using my fingers to work the gasket was better than using the ball-end tool.
07-28-2020, 01:14 PM | #21 |
$5 Dollar set of nylon tools from harbor freight helps, if you have the short trim...keeping it in the groove is challenging...tape helps some.......Spray bottle with soapy water, walk away if you get frustrated, ...1 min, it's impossible the next min, it's done....usually my wife comes out and says what seems to be the problem....it magically drops in place.
07-28-2020, 01:20 PM | #22 |
I love this!
07-28-2020, 01:15 PM | #23 |
I hired a professional outfit. They sent an older fellow who had 20 years experience including classics and the stainless trim. He struggled BIG TIME with my '67 with the short trim ( 71-72 style stainless trim ). It took him all afternoon to get it installed and I ended up helping him hold pressure on the glass to get the job done. The trim was the main problem as it kept popping out when the glass was nearly installed so he would have to start over. Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
07-28-2020, 01:59 PM | #24 | |
I pay $90- $100 for my tinted & shaded windshields and install them myself. I have done 6 or 7 of them, with and without trim. I need to put one in the Cheyenne Super cab in the next week or so and it has trim. I also need to put one in the '68 Chevy CST and it has trim also. Sometimes I use a new gasket or if I have a used one in good shape I will use it. I haven't broke one yet. (Knocks on wood.....)... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-28-2020 at 06:01 PM. |
07-28-2020, 02:34 PM | #25 |
so 335 plus tax from another guy, He said it would be 235 + but since its got the steel trim he charges an extra hundo! I like him, hes honest
