Old 04-11-2016, 02:56 AM   #176
Sac
Re: Project "Redemption" 68 SWB Fleetside
Originally Posted by SierraMtns View Post
Hey Keith,
Thanks for sharing this build with us. I will be tagging along. I know how you feel about waiting for parts. I order a rear drop member kit for my pro touring build from PB in March. Man the waiting is rough. June cant come fast enough.
June?? Wow!
Green Survivor Father/Son Truck
<SeveredTies>
Sac is offline   Reply With Quote
Old 04-11-2016, 08:11 AM   #177
mcbassin
Still Learning
mcbassin's Avatar
Nice progress on the frame!
Old 04-11-2016, 10:43 AM   #178
Bennett68C10
Bennett68C10's Avatar
Hey Keith,
Thanks for following along with my build I ordered my rear dropmember and inner frame stiffener in January. They gave me an eta of early April so I'm hoping they come in soon.
Originally Posted by Sac View Post
June?? Wow!
Its totally worth the wait though!
Thanks Mike, a few hours of work and the cross members were gone.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 04-11-2016, 12:55 PM   #179
shores6
shores6's Avatar
I love the hashtag Nate and everyone at PB has been using lately. #theresareasontheresawait Lookin awesome man.
shores6 is offline   Reply With Quote
Old 04-11-2016, 12:57 PM   #180
boostedc10
boostedc10's Avatar
Originally Posted by Bennett68C10 View Post
Also got the steering rack installed! I need to figure out what the thread size is for the tie rods because I need to trim a little off! It's a little to long right now and it's pitching the toe out in the front on the brake rotors! My rack didn't come with any jam nuts! Any body have a clue what size the thread is? It's a CPP rack!
Thread should be 9/16" -18 for all the mustang 2 racks. If you just need to cut it down some, a die grinder and thread file will be your best bet.
Here are the jam nuts for the rack
http://www.speedwaymotors.com/9-16-I...uts,26789.html
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 04-11-2016, 03:57 PM   #181
crazycrew
Holy crap! Amazing progress in such a short period of time.
Brooks -- South Louisiana
2004 Tahoe, DD
Currently on the prowl for that right C10 project
https://www.facebook.com/brooks.landry.1
IG : brolandry
crazycrew is offline   Reply With Quote
Old 04-11-2016, 05:37 PM   #182
knomadd
knomadd's Avatar
Forgive me for my ignorance, but do the rack and pinions not have left hand threads on one side like the original steering? If they do, be careful about what you trim since you'd need the appropriate tap/die to chase the threads if it's mangled a little from the trim.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 04-11-2016, 07:07 PM   #183
boostedc10
boostedc10's Avatar
Mustang II rack inner tie rods are the same on both sides. If you use a die grinder to shorten them, just buy a standard thread file to clean up the ends. You shouldn't need a die to clean them. I have done a ton of these racks this way and never had an issue. Another trick if you don't want to bother with a thread file is to just taper the very end with a grinder.
Brandon
Instagram: DRVFSTR
Old 04-11-2016, 08:21 PM   #184
Bennett68C10
Thanks, yeah I have seen that too. They can definitely make that statement!
Thanks man, sometimes I feel like I'm moving at a snails pace but that's only because I would like to have more done by now.
Keith
66 Suburban
IG: bennett68c10
Old 04-11-2016, 08:26 PM   #185
Bennett68C10
Thanks for the link Brandon, I knew somebody had to know.
The way I do it and what I did on my last setup is I thread the nut onto the rack, then trim the rack to my desired length. After it's trimmed I do like Brandon said and taper the end with a grinder. Then just unscrew the nut off the rack. As the nut comes off it basically acts as a die and cleans the threads.
Keith
66 Suburban
IG: bennett68c10
Old 04-11-2016, 08:32 PM   #186
boostedc10
boostedc10's Avatar
I knew it wasn't your first rodeo but some good questions came up
Brandon
Instagram: DRVFSTR
Old 04-11-2016, 09:17 PM   #187
ajgriffin
ajgriffin's Avatar
#Iknowbutc'monalready
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 04-12-2016, 08:17 AM   #188
Bennett68C10
Thanks for the help Brandon, I ordered those jam nuts from speedway last night.
Keith
66 Suburban
IG: bennett68c10
Old 04-12-2016, 08:45 AM   #189
boostedc10
boostedc10's Avatar
Anytime Keith.
Brandon
Instagram: DRVFSTR
Old 04-16-2016, 01:06 AM   #190
gringoloco
A guy with a truck
gringoloco's Avatar
In. I dig it. Welcome back.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-17-2016, 09:58 AM   #191
Bennett68C10
Thanks Chris
Keith
66 Suburban
IG: bennett68c10
Old 04-17-2016, 10:04 AM   #192
Bennett68C10
Went to a local swap meet yesterday and scored a 4L80e trans for $250.00! It's supposed to have 165,000 on it but I'm going to have it rebuilt and beefed up a little I was on the fence on running a 60e or the 80e due to possible clearance issues with the cab floor but I want a bullet proof trans so I'll make it fit if I have to!
Keith
66 Suburban
IG: bennett68c10
Old 04-17-2016, 10:14 AM   #193
jeh
jeh's Avatar
That's a good deal right there!!!
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 04-17-2016, 10:17 AM   #194
boostedc10
boostedc10's Avatar
Nice score Keith. I should know shortly how mine fits under my cab. I will make sure I post a bunch of pics for reference.
Brandon
Instagram: DRVFSTR
Old 04-17-2016, 11:23 AM   #195
Sac
Hell of a score!
<SeveredTies>
Old 04-17-2016, 10:57 PM   #196
RRC
RRC's Avatar
Well it looks like I'm late to the party Welcome back!! Sorry to hear about your marriage, all the best in your future!!
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712
Instagram: http://instagram.com/rockylakekustoms
Rocky Lake Kustoms
Russ
RRC is offline   Reply With Quote
Old 04-18-2016, 12:34 AM   #197
Raguemoe
Junior Member
Raguemoe's Avatar
Another OG build (hopefully we learned something on our last attempts). I'll be watching this one
Raguemoe is offline   Reply With Quote
Old 04-18-2016, 07:56 AM   #198
mcbassin
Still Learning
mcbassin's Avatar
Nice score! Beefed up is good
Old 04-18-2016, 08:26 AM   #199
Bennett68C10
Thanks Jason, I went there hoping to find one, but didn't think I would find one for that price
I'm crossing my fingers Brandon, hoping I don't have to do any additional floor mods than the high hump!
Hell of a score!
Thanks, I'm pretty excited about it. Saved me a ton of money over buying a brand new trans.
Your never to late to join the ride Thanks, the future is looking pretty good.
Thanks for checking out my next journey. I know I definitely learned what not to do The key for me is not letting my brain go wild and start changing everything before its built.
Thanks Mike, maybe someday in the distant future I would like to add a little power adder to the motor. I don't want a transmission that will grenade the first time I mash the throttle.
Keith
66 Suburban
IG: bennett68c10
Old 04-18-2016, 09:46 AM   #200
MMcMasters
MMcMasters's Avatar
Great progress in such a short time!! It will be fun to follow along and see how it turns out!
Mike
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
