10-15-2020, 11:55 AM | #1 |
Fuel filter leak?
Sorry for the ignorance, guys. Is this my fuel filter? It’s leaking like mad. Couldn’t figure out why I was dying from fumes on last night’s cruise and this morning’s puddle clued me in.
10-15-2020, 01:05 PM | #2 |
Moderator
Re: Fuel filter leak?
That's an aftermarket filter that should be addressed. Never seen one like that though so I can't be of technical help there.
10-15-2020, 05:29 PM | #3 |
Who Changed This?
That appears to be a fuel filter (not stock, I think), and it shouldn't be on the suction side of the pump unless it was the factory one, which is pretty big, IIRC. I'd just take it out and replace the flex line while I was in there. There should be a filter in the carburetor, unless you have an Edelbrock (I suspect this because that other item appears to be a pressure regulator).
10-15-2020, 06:35 PM | #4 | |
10-15-2020, 06:51 PM | #5 |
Just here to tinker
Replace with a one piece filter. Please don't use the 3 piece glass filter from your favorite auto parts store. They are fire starters. Just get a regular one-piece plastic unit and call it a day.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
10-15-2020, 06:54 PM | #6 | |
WIX Filters - 33003 Fuel (Complete In-Line) Filter, Pack of 1 https://www.amazon.com/dp/B000CSEUPG..._ulnIFbX8Q5SQA |
10-15-2020, 07:39 PM | #7 | |
Who Changed This?
10-16-2020, 11:44 PM | #8 |
Being All The Engine Heat Not Helping Matters Aluminum Attracts the heat Get a Clear Plastic one put in Front of Engine with fan Air
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
10-16-2020, 11:45 PM | #9 |
Being All The Engine Heat Not Helping Matters Aluminum Attracts the heat Get a Clear Plastic one put in Front of Engine with fan Air Hitting it
