Old 07-19-2019, 04:35 PM   #1
Freddo
Correct Spark plugs?
Hi,
I have owned this 1967 Chevy C 10 for several years. It is or at least appears to be mostly original. It has a 283 and I am getting ready to give it its first major tuneup. I ordered the tuneup supplies from rock auto and ordered the AC Delco R-45 plugs. I am removing the existing plugs and see that they are quite a bit different, the threaded area appears to have more threads and they are longer. I did a search on spark plugs here on this site but didn’t see anything that referred directly to this. I included a picture of the two different plugs. Can you tell me if it is OK to use these R-45plugs in place of these old plugs?
All help appreciated! Thanks!
Freddo is offline   Reply With Quote
Old 07-19-2019, 05:02 PM   #2
Mbeef61
Mbeef61's Avatar
Re: Correct Spark plugs?
One is tapered seat and one is gasket seat. They cannot be interchanged. I have gasket seat on my 69 heads. You have to look at the thread seat in the heads to determine. If unsure post a pic that may help. Not sure if they switched from one to another for different years. Things get swapped so much on these rigs it’s hard to go by a catalog.
Mbeef61 is offline   Reply With Quote
Old 07-19-2019, 05:03 PM   #3
Mbeef61
Mbeef61's Avatar
If the ones that were in there were correct you need r45ts plugs
Old 07-19-2019, 05:46 PM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I'm reminded of the time I tried to put 402 plugs in 396 heads Knew I had a 402, forgot the heads were switched out.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-19-2019, 07:38 PM   #5
Freddo
Thank you for the help on the spark plugs Mbeef61! I just went down and bought the correct ones. Looking forward to getting them in. I’m not sure what kind of hassle is involved with returning plugs to rock auto or if it is even worth it, but I guess I will check it out. I have been wanting to do a compression test on this motor for a while. I did the test while I had the plugs out and most of the plugs Landed in the 140 to 155 psi range which I thought was excellent except for cylinder number seven which came out at zero. (Ouch!) That was a surprise because it is a very smooth running engine. It uses some oil and is older so I expected less compression on all of the cylinders but not a dead one. I thought I would pull the valve cover off and see what was going on with the rocker. Are there any other easy to do tests that you might suggest? Thanks!
Old 07-19-2019, 07:49 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
That's a lot of plugs! Did the 402 get the taper seat plugs in '71? Mine still has the N-type 14 mM long reach.
~Steven
Simi Valley, CA
Old 07-19-2019, 08:22 PM   #7
RustyPile
RustyPile's Avatar
Originally Posted by Freddo View Post
..........<snip>..... I have been wanting to do a compression test on this motor for a while. I did the test while I had the plugs out and most of the plugs Landed in the 140 to 155 psi range which I thought was excellent except for cylinder number seven which came out at zero. (Ouch!) That was a surprise because it is a very smooth running engine....<snip>....... Thanks!
Those two statements contradict each other.. Either your compression test is flawed, or your perception of a "smooth running engine" is flawed.. With zero compression that cylinder is completely dead, leaving a "gap" in the firing cycles.. The miss is most evident at curb idle.. I suggest you either conduct another accurate compression test or have an experienced person take a look/listen to the engine...
RustyPile is offline   Reply With Quote
Old 07-19-2019, 11:23 PM   #8
71CHEVYSHORTBED402
Factory 402 heads take the tapered plug. That's not to say GM never built one otherwise. So 71 is generally correct. If I recall, there was a slow transition 396 to 402, which occurred in some 1970 The trucks are badged 396, but have 402 blocks. Makes me ponder if GM assembled "396" heads on 402 blocks
I can't speak for all 396 heads, mine came off a 68 HP Camaro. They generally or always take the flat-seated gasket type plug.
Tony
Old 07-20-2019, 12:53 AM   #9
Mbeef61
Mbeef61's Avatar
You can see if they will take the plugs back. If not just sell them on here. Those are the plugs my heads take. Fairly common. Good plugs too. You can squirt a teaspoon of oil or so down the plug hole and see if the compression increases, it may work but usually for slow building compression not zero
Old 07-20-2019, 12:56 AM   #10
Freddo
I would have to agree with you. I have never seen an engine that had a dead cylinder that did not have a miss. This engine runs relatively smoothly through all RPMs. I ran the compression test three times on that cylinder and got zero pressure each time. It seems odd that the compression tester would give solid readings on the other cylinders but zero on this one. Maybe more testing is needed. Thank you for the advice!
Old 07-20-2019, 12:58 AM   #11
Freddo
Thanks again for the info & advice!
Old 07-21-2019, 02:48 PM   #12
Freddo
Well, the mystery of the dead cylinder is solved. I took a fresh look at it again, screwed in the compression tester and cinched it down fairly tight. When I tested it, the cylinder showed 125 pounds. All in all, for an older engine not too bad. One additional question: I installed new spark plug wires along with new plugs and a small packet of silicone grease came with the spark plug wires. Probably a dumb question, but does anyone know what this is used for?
Thanks!
Old 07-21-2019, 04:24 PM   #13
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
The silicon is used to smear the inside walls of the plug boots to allow easy slip on and off...It also helps seal the plug boots...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 07-21-2019, 07:11 PM   #14
Mbeef61
Mbeef61's Avatar
It’s used to keep the boots from sticking to the white porcelain. I apply it to the white porcelain and the inside of the boot. Just a light coat on each. It’s not for the connection area but some people put it there for some reason.
Old 07-22-2019, 04:06 PM   #15
Freddo
Thanks for the info!
