Old 06-13-2008, 03:30 PM   #1
Hair
"HEAT" fuse
What is the fuse for that says "HEAT" beside it. As you can see, mine is missing. My heater works fine. My blower works and there's nothing else electrical about the heater...that I know of anyway... so what does this "HEAT" fuse do anyway?
Hair is offline   Reply With Quote
Old 06-13-2008, 06:27 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: "HEAT" fuse
I wonder if this diagram we've been useing for so long might be off a little.
Do your turn signals work?
Old 06-13-2008, 06:32 PM   #3
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: "HEAT" fuse
The fuse labeled Air Cond should really be Air Cond or Heat, depending on what you have. Use a 10 amp fuse for heat only trucks, and a 25 amp fuse if you have factory AC. The fuse labeled heat is for the radio, but with the right size fuse, could be used for any load that you want on in run or acc. In the first photo, he is pointing at the horn relay.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 06-13-2008, 09:07 PM   #4
muddyblazer02
muddyblazer02's Avatar
Re: "HEAT" fuse
The size of wire behind the fuse socket will determine the load capacity of the circuit, and thus will determine what size fuse you could and should use. If you put a fuse in there that is too much for the circuit, you will over load it and potentally start a fire.
muddyblazer02 is offline   Reply With Quote
Old 06-14-2008, 02:55 PM   #5
oldgold70c10
Who's got steelies?
Re: "HEAT" fuse
You can use any size wire up to a 12 guage, and the corisponding fuse size, since the radio fuse powers the plug terminal above it. The heat/AC fuse size is based on the factory markings on the fuse panel.
My Truck Page
My Youtube Channel
Old 06-16-2008, 07:23 AM   #6
Hair
Re: "HEAT" fuse
Everything on my truck works just fine except for the radio, it is dead. I bet that's why. I'm going to stick a fuse in there and see if it comes on. If it works, then I bet I'll see out why they took the fuse out :-) It has the original eight track in it, I hope it works, that will be cool!
Old 06-16-2008, 06:51 PM   #7
oldgold70c10
Who's got steelies?
Re: "HEAT" fuse
That would be cool if it did work. Chances are though, if it still has the original speaker that the voice coil on the speaker is open and the set won't play. The original speaker was 10 ohms impedence, but modern 8 ohm units work just fine in their place.
My Truck Page
My Youtube Channel
