Old 05-20-2011, 05:34 PM   #51
JWPOORE
Re: Blazer interior rear panels
Originally Posted by FuelCellGuy View Post
Ok, I have really dropped the ball on this one. We have been extremely busy and short handed (had a guy quit, I know in this economy, that's unheard of). What I CAN offer right now is full size paper patterns so that anyone can produce them from the material they want. I can do $25 + shipping in the continental US. Eventually, I will produce the panels, I just don't have the time for R&D right now. Thanks everyone.
Might be a dumb question, but would these patterns include one for the drivers side and one for the passenger side? I was not sure if they were exactly the same, only reversed or if there is any specific differences or cutouts between the two sides.
If you take Paypal, I would be interested in a set of patterns, just would need to know the shipping cost to zip code 93637.
JWPOORE is offline   Reply With Quote
Old 11-15-2011, 11:08 PM   #52
ChrisCostlow
Junior Member
I too am really interested in the paper patterns for the panels. How much to ship them to 92315?
Do you also have a drawing or anything for the standoff brackets?
Thanks in advance!
Chris
ChrisCostlow is offline   Reply With Quote
Old 08-24-2019, 06:31 PM   #53
LovelandK5
You still offering panel patterns?
LovelandK5 is offline   Reply With Quote
Old 08-25-2019, 09:39 AM   #54
A1971Blazer
A1971Blazer's Avatar
This is what I did for my '70 CST
3/16" textured ABS plastic sheet....less than $100 for a 4' x 8' sheet
anodized aluminum "J" trim
vinyl push-on trim for the edges
I found a pattern with the dimensions on line
these fit so snugly...I only put in 4 trim screws to hold them
The only issue is black only....which was fine for me when I switched from blue to black interior
stopped it at the B pillar and added the vinyl trim
you can see one small black screw here
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 08-25-2019, 10:18 AM   #55
myjimmyrocks
[QUOTE=A1971Blazer;8581705]This is what I did for my '70 CST
Do you happen to remember where you found the pattern? Thanks
myjimmyrocks is offline   Reply With Quote
Old 08-25-2019, 01:13 PM   #56
jondancer
That looks better than the stock ones !
jondancer is offline   Reply With Quote
Old 08-25-2019, 02:47 PM   #57
A1971Blazer
PM me and I'll send you a PDF file
I can also get you the info for the trim
Name:  SIDE PANELS[1].jpg
Old 08-25-2019, 07:53 PM   #58
notsolo
notsolo's Avatar
Also Azek PVC board comes in 4' x 8' sheets. Smooth finish, 3/8" is what I used,..About $80. scuffed and primed with epoxy paint, urethane base coat over. No top trim, pvc piece glued 90 degrees on top, cut to fit the profile. 4 screws hold it in place.
notsolo is offline   Reply With Quote
Old 08-25-2019, 08:42 PM   #59
Martyt
I see a guy on Ebay is selling what looks like a repro rear side panel; have you looked into that option?
Under Restoration (11/19 estimated completion date): 72' Cheyenne K10 short bed, 4spd with orig factory tilt and orig eng and tran, am/fm radio, tach, manual throttle, med. bronze met. tow hooks, Factory Build Sheet, Protecto Plate, etc
Future Restoration: 72 Jimmy 4x4 Cheyenne--great driver! (love my Jimmy)
Martyt is offline   Reply With Quote
Old 08-26-2019, 10:38 AM   #60
JMac11
JMac11's Avatar
A1971Blazer- Where did you source your plastic and j channel....... Looks good, might be a market for these
JMac11 is offline   Reply With Quote
Old 08-26-2019, 11:11 AM   #61
A1971Blazer
The plastic sheet came from Piedmont Plastics locally...most all plastic suppliers have it...ABS "hair cell" sheet 3/16" thick
The J channel and vinyl push-on trim came from McMaster-Carr supply Co
aluminum J channel https://www.mcmaster.com/8427a64
trim material https://www.mcmaster.com/8451a47
Old 08-27-2019, 09:18 PM   #62
Woodsloafer
Junior Member
Following
Woodsloafer is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
