Old 03-22-2021, 11:13 AM   #26
blazer2007
Re: cracked flexplate sound but not cracked ?
update. Got new flex plate, starter, harmonic balancer and freshened up the dist. Still have the noise. Pulled plug wires one at a time while running and still the noise. Starter has lots of room when running but might throw a shim in there and see. Took valve covers off again and turned motor over with no ign. power and no noise and valve train all looked good. The next simple thing to try is mech. fuel pump. I,ve read alot of noises coming from there. I getting stumped without actually taking the motor apart which is OK if I have to do it. If you think of other tests I should try please let me know. The noise is the same at all times , hot or cold but only when running. Oil pressure is good
Last edited by blazer2007; 03-22-2021 at 11:46 AM. Reason: fotgot something to add
blazer2007 is offline   Reply With Quote
Old 03-23-2021, 08:57 PM   #27
AussieinNC
Moderator
AussieinNC's Avatar
Suggest you change the distributor out....
When you have it out, check the end play on the camshaft...can almost guarantee there is too much end float on the cam....it will chew up the gear on the distributor and cause a similar sound to what is in your video.
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 03-24-2021, 08:39 PM   #28
blazer2007
Thanks, did that, gears are fine. Took out mech. fuel pump which is a year old and nothing.
Old 03-29-2021, 11:00 AM   #29
blazer2007
Well , I talked to my nephew and he has raced oval track cars for along time from crappy hit to pass to modified. He had the same problem one day and when they removed the oil pan some of the windage tray had broke loose and there was apiece hitting the crank or rod and making the ting ting noise. Makes sense to me as nothing changes the sound on mine and stethoscope would not find it . Here,s hoping
Old 04-05-2021, 11:56 AM   #30
blazer2007
well that wasn,t it. I wiggled rods but didn,t have any movement except sideways but they say is normal. HMMMMM.
