Old 03-12-2021, 10:10 AM   #1
71nFun
carburetor size question?
ok folks... engine is SBC350 bored .040 with sportman 2 heads 2.02 valves. edlebrock performer intake. cam is semi mild with .490 lift. 112 lobe sep. MSD 6AL ignition. question is whats a good size carb to go with?
71nFun is offline   Reply With Quote
Old 03-12-2021, 10:40 AM   #2
geezer#99
geezer#99's Avatar
Re: carburetor size question?
Your engine Specs are about like a sb I built but I used twisted wedge heads.
I used a Holley 3310 750 vac sec.
Old 03-12-2021, 11:23 AM   #3
71nFun
Thank you. was thinking 750 but didnt want to have too much carb. heads seems like a decent flowing head but cam isnt very stout. Thanks for the tip!
Old 03-12-2021, 06:27 PM   #4
PGSigns
PGSigns's Avatar
I have a Holley 670 street avenger on my 66 with a L31 crate engine about the same cam and a super victor. Runs really good.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-13-2021, 06:14 PM   #5
garyd1961
I just happen to have a new 770 street avenger when I installed my L31 so I used it. I did reject the primaries down a couple sizes but it runs good. I always heard you can get away with an oversized carb if it's vacuum secondaries.
garyd1961 is offline   Reply With Quote
Old 03-16-2021, 09:58 PM   #6
Captainfab
60-66 Nut
A 600 cfm carb is sufficient for a 357 cu in engine if you aren't turning it much over 5000 rpm.
Old 03-17-2021, 06:46 PM   #7
mattfranklin
mattfranklin's Avatar
Holley 770 Truck Avenger on top of a 1970 stock cloned LT-1 350 (reasonably close to stock Corvette LT-1/Z-28 specs for 1970), 0.030 over.
As GM designed it, their LT-1 came originally with a 780 Holley 4150 (of the 3310 family), so that's why I picked something similar for my clone.
Runs and idles great once tuned.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 03-19-2021, 08:22 PM   #8
Tom
driving is in my blood
Tom's Avatar
Its a 350 with a small intake, no idea on cam but a hydro flat tappet with .490 lift is usually around 230@.050 so medium cam, and decent but not great heads. I'd put a 600 on it. 750 will work fine too but more then needed.
Old 03-19-2021, 09:49 PM   #9
Captainfab
60-66 Nut
Here is an online calculator on Holley's website.
https://www.holley.com/products/fuel...s/carburetors/
