Old 02-25-2010, 05:19 PM   #26
GMC Guy
GMC Guy's Avatar
Re: My 86 C10 Project
dude that thing is sweeet
did you ever figure out what happened to the first 350?
and boy did you luck out with that paint and body...that paint looks amazing, and all it took was some elbow grease...
if i did that to mine, i think all the paint would end up chipping off
oh and what wheel size and backspacing are those new rallies?
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 02-25-2010, 05:26 PM   #27
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Man alive! That is a sweet looking truck. I always love to see one "saved" from a yard. Good job on it! Keep at it, it sounds like you will.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 02-25-2010, 06:46 PM   #28
JW76
JW76's Avatar
Thanks for all the comments. The first 350 was just tired. It had been rebuilt twice and was used hard. I got it cheap enough that I could run it for the summer while building a good motor. The paint is really good on the truck. The roof paint is thin though with primer poking but you can't see that at a car show. I hit it with some spray can which matched close. The paint dulls out pretty quick so I just wash and wax it every other week and the looks good.
JW76 is offline   Reply With Quote
Old 02-25-2010, 08:00 PM   #29
kghtrdr272
Easy Rider
kghtrdr272's Avatar
Great job on the truck, can't wait to see the progress. I'm currently working on a frame off on my '85 GMC. I'll be posting a build thread soon.
kghtrdr272 is offline   Reply With Quote
Old 03-04-2010, 04:45 PM   #30
JW76
JW76's Avatar
With some inspiration from Wild83c10 I am going to continue my trailing arm conversion. I did all the research last year but decided to wait. Well after talking with CPP and Steve at HRH its a go. I am going to have HRH build my crossmember, I will use stock arms, and I am going to use the CPP notch/spring mount and springs. Hopefully my build will help people with longbeds utilize trailing arms.
Old 03-05-2010, 10:34 AM   #31
JohnC
JohnC's Avatar
Nice looking truck. It has come a long way. Keep up the great work, and the updates.
On a side note. What belt bracket setup are you using?
JohnC is offline   Reply With Quote
Old 03-05-2010, 12:00 PM   #32
JW76
JW76's Avatar
its just the old v belt setup that came with the 350. thanks for the compliments
Old 03-24-2010, 11:38 PM   #33
JW76
JW76's Avatar
sneak peak of coming attractions... all the parts are in for the trailing arm conversion... just go the last piece today... the crossmember by HRH...
Old 11-28-2010, 08:33 PM   #34
JW76
JW76's Avatar
Some updates... its been a while
These are cell phone pictures I snapped after working this weekend. I have the trailing arms all mocked up and am finishing up welding. Finally, a long bed with trailing arms!
Old 11-28-2010, 08:35 PM   #35
JW76
JW76's Avatar
I will take good pictures once I finish welding everything up for good. This was the tacking and mockup stage so unfortunately it is all disassembled again.
Old 11-30-2010, 11:00 PM   #36
JW76
JW76's Avatar
Just got my new fuel cell. This weekend I should be able to get the trailing arms back on, the leafs off, and that all finished. I would also like to get the fuel cell in. My goal is to have the truck ready for the Powertour in June! It seems ambitious but doable!
Old 11-30-2010, 11:06 PM   #37
JW76
JW76's Avatar
I've been reading Robnolimits suspension thread and intent to incorporate a few of his suggestions such as x bracing and boxing a few important locations on the frame and the strategic placement of weight. My fuel cell is going between the frame rails after the axle to put that weight in the ideal location. instead of a few hundred pounds hanging off the drivers side like the old saddle tank. The battery will also be relocated in a saddle box off the rear rail. I am working on a deal also to acquire a NOS cheater kit. My new engine should be 525 on motor + 250 shot of nitrous. I would also like to use a snow meth injection setup. Should be fun when combined with the new 12 bolt with 3.73s and my new TH400 with reverse shift pattern manual valve body and 2800 stall converter!
