Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Suspension, Steering and Brakes
Old 04-25-2004, 12:39 AM   #1
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Borgeson Steering U-Joint Review.
Bought the U-joint with Vibration Dampner ($70). What a difference. My steering is much tighter and any vibration from the 38's is gone. THis is a must have for lifted trucks. The stock joint on the column side was worn out I think mainly due to the 3 inch body lift i'm running. No pics of the install but I can tell you how easy it was.
1. Remove old Shaft. (One bolt at the box and on the column.)
2. Hack the old upper joint off with a hacksaw.
3. Heat up the shaft with a torch (Plastic inserts will melt and it makes the shaft collapable.
4. Shaft will have to be hacked down a little more because it doesn't cpllapse inside too far.
5. Install U-joint on shaft. Size is 3/4 inch 36 spline x 3/4 inch DD.
6. Drill and pin the shaft when desired length is chosen.
7. Re-install.
Great product.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline
Old 04-27-2004, 10:11 PM   #2
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Originally posted by bouncytruck
I'd like to see pics too. Is the part an off the shelf part. I know you were looking for measurements for a while.
Yeah, off the shelf. Just ask for a 3/4 inch 36 spline (column side) x 3/4 inch DD (Steering box side). They have to know this for mounting the vibration dampner. They sell with and without the dampner but do your self a favor and get it. I am talking ZERO shaking with huge tires.
Old 04-28-2004, 01:49 PM   #3
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Originally posted by IoWnZa
I wonder if they also work well for Stock/Mild lift applications. I don't run a Lift on my Blazer, and have 32's. I want something to remove some of the Vibration, there isn't much, but it's still there.
Yeah. You could do it.
Old 04-29-2004, 08:38 AM   #4
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Originally posted by 454_72_4X4
Does this just replace the upper U-joint, (column end)?
Just another suggestion on the subject. I used a shaft, (intermediate?), out of an Astro van on my S-10. They have U-joints on both ends and no rag joint. (Had to stretch it a little!)
I don't know if it would work on the older trucks though.
Yes. Replaces the Cloumn end Rag Joint.
The stock shaft is fine to use, It is collapsable and the steering box end already uses a U-joint.
Old 06-07-2004, 06:17 PM   #5
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Originally Posted by Yukon Jack
Could you get a pic of it installed?
Here. Finally got a Digicam.
Old 06-08-2004, 10:51 AM   #6
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Thanks for the pic. Looks great. Does it mount to the steering box the same way - using the rubber thingie (highly techinical term, eh?).
Rubber thingy? Column end mounts directly to column end with splines. Steering box side just bolts to the Double D end of the U-joint. Steering shaft was shortened for this. No rubber thingies.
Old 06-08-2004, 12:26 PM   #7
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Sounds great. If you don't mind, when you get a chance, shoot a picture of the connection at the gear box.
Will do. The gear box has it's own stock u-joint though. Nothing special.
Old 06-08-2004, 01:50 PM   #8
WHSmith
A lot of the trucks have the rag joint on the steering box end of the shaft. I went with Borgeson parts and put their vibration reducer by the steering box and one of their u-joints at the column end of the shaft. The shaft in the box is a 3/4 x 30 spline and it's simple to remove the rag setup and replace it with the new hardware.
WHSmith
WHSmith is offline
Old 05-09-2005, 10:58 AM   #9
Yukon Jack
Mechanically Challenged
Yukon Jack's Avatar
Where did you buy the vibration dampner?
1970 Blazer with a 400 sbc and 4" lift Roadworthy!
1969 K20 with a 454, a bit of lift and 35's
1980 Pontiac Trans Am, 455 Oldsmobile
Yukon Jack's Web Pages
Yukon Jack is offline
Old 05-09-2005, 02:43 PM   #10
2wdBlazer
The Blazer King
2wdBlazer's Avatar
www.borgeson.com of course!!!
Old 06-02-2006, 02:22 PM   #11
orange72blazer
orange72blazer's Avatar
Re: Borgeson Steering U-Joint Review.
I just got done doing this to my 72 blazer, I went with the standard 13/16-36 spline u-joint at the steering box to replace the rag joint and left the joint at the column stock for now. This worked very well and I dont have any binding like I did before or any more vibration than I did with the rag joint. You can get these joints from Jegs or Summit.
1972 Chevy Blazer
1997 GMC Sierra
2009 Chevy Tahoe
orange72blazer is online now
Old 08-24-2006, 04:26 PM   #12
Yukon Jack
Yukon Jack's Avatar
After my rag joint ripped I ended up adding a Borgeson U-joint at the steering box and I added a Borgeson telescopic shaft (1" DD x 3/4" DD) to my 69 K20. I had previously added a Borgeson U-joint at the steering column.
Here is a pic of the u-joint which is 3/4" x 30 spline and 1" DD to fit the power steering box I'm using which is from about a 1978 Chevy 4x4.
and a pic of it at the steering column - the steering column is not secured yet so ignore the block of wood that has the column wedged in place. That U-joint is 3/4" x 36 spline and 3/4" DD.
The telescopic shaft ended up being about 11 1/2" long but I'm using a van tilt column.
Old 08-24-2006, 05:54 PM   #13
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Why use the borgeson shaft when ours can become collapseable?
Old 08-25-2006, 11:18 AM   #14
Yukon Jack
Yukon Jack's Avatar
The lower u-joint is 1" DD for the steering shaft. It did not appear that I could cut off enough of the stock shaft to get to the DD area. The first few inches of the stock shaft at the rag joint end are round then it tapers to DD.
Old 01-29-2007, 02:19 AM   #15
1969 GMC
1969 GMC's Avatar
sorry to drag this one up from the dead, but what is the borgeson pn# of the damper?
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline
Old 01-29-2007, 02:41 AM   #16
1976K5CHALET
1976K5CHALET's Avatar
Anytime...the dampener is an option when you buy the shaft...it is integrated into the shaft. If you go to their web site you may be able to buy it seperately as i think they sell some of the components seperately so you can build your own custom shaft.
I'm out working in the patch so i do not have access to my records otherwise i'd get out the invoice and post it for you.
Email me anytime at k5nutt@hotmail.com.
2wdBlazer...the borgeson shaft is made to colapse in an accident just like the factory unit.
DW
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline
Old 01-30-2007, 03:33 AM   #17
1969 GMC
1969 GMC's Avatar
uhh...i'm pretty sure you can just buy the damper/ujoint by itself since that is what 2wdblazer did before he made this thread.
1969 GMC K2500
1996 Honda Accord
1969 GMC is offline
Old 01-30-2007, 11:17 AM   #18
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Yep. I just called Borgeson and told them the shaft size and spline count. The steering column side is 36 spline x 3/4 DD.
The steering box side may be divverent on the splines and if the steering box was changed to a 77+ style the splines could be different yet again.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
