12-31-2006, 11:06 AM | #1 |
Internet score: Upgrading STOCK Vortecs
I was searching on Vortec information and came across this Vortec article from CarCraft. The article below provides details, but it's possible to upgrade stock Vortec heads to allow .550 lift with no machining using CompCams "beehive" springs. Upgrade cost of about $275 for a total cost of $835 for a pair - assuming you do your own assembly. SDPC sells a machined and spring-upgraded set using GM ZZ4/LT1 "HOTCAM" springs good for .525 lift for about $700. I have NOT personally done this swap.
Springs Comp Cams 26915 $186 OR Comp Cams 26918 $186 Retainer, steel Comp Cams 787-16 $59 Keepers, 7-degree Comp Cams 648-16 $28 Dual spring kit Comp Cams 986-16 $85 Retainers for 986 spring Comp Cams 740-16 $60 Keepers, 10-degree Comp Cams 611-16 $26 http://www.carcraft.com/techarticles...ade/index.html http://www.sdpc2000.com/catalog/2172...ng-Upgrade.htm Last edited by Billla; 03-01-2007 at 10:06 AM. Reason: CORRECTED based on experienced feedback: retainer P/N changed |
12-31-2006, 11:55 AM | #2 |
Re: Internet score: Upgrading STOCK Vortecs
I AM REALLY LIKING THESE VORTECS
i just drilled the stream holes yesterday..have a stud boss cutter on the way to install screw in studs.. comp cam makes a spring seat cutter for use with a hand drill. for up grading springs as well.. just trying to make sure i get the correct tools (cutters) maybe you can help me out bill from what i understand what kills the lift on the vortec heads is the valve stem height.. so two cutters are needed... one that cuts the spring seat.. one that cuts the seal area... is this correct? i will go read your new tech articals now thanks bill http://www.amazon.com/COMP-Cams-4718...U&s=automotive Last edited by rage'nrat638; 07-12-2007 at 06:59 AM. |
12-31-2006, 12:50 PM | #3 | |
Yep, this is correct - they use the guide boss as a locator for the spring and for the very tall stock valve seal. I believe Goodson (www.goodson.com) makes a cutter that can do BOTH cuts in one operation, but I haven't looked at it yet. Cutting the valve boss is something I wouldn't tackle at home unless you have the setup to do it...and the cutters/pilots ain't cheap :/ Last edited by Billla; 12-31-2006 at 12:50 PM. |
12-31-2006, 02:09 PM | #4 |
I remember that article. So basicly you can take stock un modified vortec heads and use the behive springs and run more lift RIGHT? I am looking for a set for my older block and have a 480 lift cam. I like the flow and the smaller chamber will give more compression from 76cc. Jegs told a friend of mine you have to drill holes for colling for a 350 block, whats that all about? I didn't think 350's needed steam holes?
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
12-31-2006, 02:14 PM | #5 | |
You do not need additional holes for cooling on a 350; that's only for the 400 "steam holes" due to the siamesed bores. |
01-15-2007, 07:33 PM | #6 |
bought those items on ebay and saved a few bucks.
springs http://cgi.ebay.com/ebaymotors/COMP-...spagenameZWD1V retainers and locks http://cgi.ebay.com/ebaymotors/COMP-...spagenameZWD1V http://cgi.ebay.com/ebaymotors/COMP-...QQcmdZViewItem 235.00 for every thing seals i picked up at napa 23.00 for 16 total nice seals Last edited by rage'nrat638; 07-12-2007 at 06:59 AM. |
01-15-2007, 08:02 PM | #7 |
a couple of the goods
01-15-2007, 08:08 PM | #8 |
what the hay.. a couple more
01-16-2007, 03:51 AM | #9 |
ragenrat, have you measured to see what you have for clearance between the bottom of the spring retainer and the top of the valve seal? I wonder how the difference in clearance is made up? Thinner retainer that sits up higher on the valve stem?
Also, there appears to be another solution that doesn't require machining, crane spring kit 10309-1 includes all needed parts to allow vortec heads .550 lift and is a bit cheaper too, kit runs at summit for 169, there is a quick write up a the bottom of this page on this link http://www.gilbertchevy.com/frame.ht...ds/Vortec.html who wants to try out the crane solution?
72 Chevy C20 Longhorn 72 Chevy, K20 Custom Camper 67 Chevy, LWB, C20, 350/350, PS, PB, 65 Jag MKII |
01-16-2007, 04:51 AM | #10 |
KEEP ON TRUCKIN'
Nice work and great advice.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
01-20-2007, 06:16 PM | #11 | |
well heres a picture of the retainers that were on the vortec heads i have (stock) ? verses the LS1 retainers this distance will add to the lift factor 5/16" of a inch seems to be the difference Last edited by rage'nrat638; 07-12-2007 at 06:58 AM. |
01-21-2007, 11:34 AM | #12 |
hey i got my new spring compressor.. off ebay for 20.00 shipped.. after two weeks
this thing makes short work of changing springs Last edited by rage'nrat638; 07-12-2007 at 06:58 AM. |
01-23-2007, 12:34 AM | #13 | |
Thanks for that picture, as the saying goes "a picture is worth a thousand words" Now get it why you can drop in a new set of retainers/springs/keeprs/locks and be set up for a more aggressive cam.
02-11-2007, 11:15 AM | #14 |
The retainers you used are the incorrect ones for the iron Vortec heads. You are using retainers for the different sized valves teh GEN3 engines are running(774-16), and not the 11/32" 787-16 you should be running for teh GEN 1 Vortec heads.
I dont know what will happen if anything, but the incorrect retainer was used. peace Hog |
02-11-2007, 11:39 AM | #15 | |
welcome to the board |
02-11-2007, 11:50 PM | #16 |
Is there any type of valve alignment or anything else like that to do when changing valve springs? Or will the valve be centered by the shape of the valve seat?
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
02-12-2007, 12:05 AM | #17 |
GEARHEAD
I'm not exactly sure about your question graywOlf. But if your asking about the vale being centered in the valve pocket the valve guide (internal) keeps the valve centered in the head.
02-13-2007, 11:50 AM | #18 |
Another thing to keep in mind is the self aligning rockers that were used on these from the factory. You still have to use them unless you go to screw in studs.
69 Chevelle SS 375/396 TKO 600 71 Suburban 3/4 4x4 402 5-speed (project) 68 chevy C10 shortbed 327 5-speed (project) 72 Blazer 4x4 400 4-speed (wifes project) Numerous 67-72 parts trucks |
02-15-2007, 11:42 AM | #19 | |
On a budget like Fred Sanford
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
02-15-2007, 08:50 PM | #20 |
OK GUY'S I JUST SENT A E-MAIL TO CAR CRAFT...
on this topic, posted the link to this very thread, so we can get to the bottom of this retainer deal. i will let you guy's know as soon as i do. i have not yet installed my heads. and want this to be right. your pal mark |
02-15-2007, 11:45 PM | #21 |
The difference is in the valve stem diameters. They may look close, but they're not the same. The GM LS retainer/keepers won't fit properly on a Gen-1 valve stem, so CC made some that will.
02-17-2007, 09:06 PM | #22 |
Glad I could be of some help. Can you guys keep us informed as to what CC response is please.
i have a 1997 reg cab shortbox, Vortec 350 truck and I would like to install a camshaft with more lift to compliment my new intake manifold with 29 pph EV6 injectors. Here is a pic of the intake as shipped from GM before mercruiser sprays it red. http://www.sfatek.com/images/efi.jpg I did the install myself. All teh marine intaek components cost over $300 US, but I bought my intake used and did teh install including PCM tuning for $995US. I did teh retrofit myself. Notice theexternal fuel rails and fuel pressure regulator. No more 400 crank hp barrier with teh stock 19 pph poppets. The stock poppet injection spider was actually insid eth intake manifold on the stock L31 Vortec intake restricting flow. If anyone wants any info on the intake manifold conversion, let me know. Thanks for the welcome. peace Hog |
02-26-2007, 12:18 AM | #23 |
Re: Internet score: Upgrading STOCK Vortecs WTF
well i have not heard dick from car craft.. i just ordered the supposed correct retainers . should be here in a few days pictures to follow...
02-28-2007, 07:33 PM | #24 |
well i have not heard anything from car craft
so i went ahead and bought the new 787-16 retainers i will be installing these this week end. we will see what the difference is Last edited by rage'nrat638; 07-12-2007 at 06:56 AM. |
03-19-2007, 08:57 PM | #25 |
Oilfield Trash
any updates?
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
