Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 08-19-2007, 04:24 PM   #1
CJ5 Convert
CJ5 Convert's Avatar
67-72 Printed Circuit Layout
I'm not sure if this will help anyone. But, I have been trying to figure out all of the mess in the wire loom that is the connector for the guage display so I could adapt it to my new American Autowire fuse panel. The info I had with the stuff I found out GMC Pauls website, (yall should check out his page it has the other wire loom layout), finally helped me put this together.
http://www.gmcpaulstruckparts.com/Tech%20Tips1.htm
I'm not to smart so I made this so I could print it out and have it all on one page. If it helps someone cool. I think it came out allright I had to sample it at a lower rate to get it to post. Thanks to all of you that have been helping me. -Jason
Allright I can't get this any bigger. I guess because of the limit on pixel width.
If you need the big one PM me it's like 3 mb's (ok it's not three meg's but still to big to fit).
Name:  Dash  Layout Final.jpg
Name:  Dah lYOUT.jpg
- Jason
Orange Crush - 1969 K5 Blazer CST 4WD MONEY PIT
1975 CJ5 Renegade - Levi's Edition - 304 V8 original paint
Last edited by CJ5 Convert; 08-19-2007 at 09:27 PM. Reason: Cause I'm to dumb to figure this out.
CJ5 Convert is offline
Old 09-06-2007, 12:59 PM   #2
AH619
AH619's Avatar
Re: 67-72 Printed Circuit Layout
please explain wire 12 it says terminal by battery. my truck will show discharge but never shows charging. even though it is. what terminal by the battery is it refering too? and thanks this diagram is great
72 2wd lwb cheyenne super youngest son.green/white
72 2wd lwb cheyenne super oldest son.green/white
71 4wd 3/4 cheyenne super frame off manderin
copper / white 4 inch lift. FINALLY DONE / SOLD
72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO
REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR
COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856
AH619 is offline
Old 09-06-2007, 01:18 PM   #3
CJ5 Convert
Allright AH619 you may want to ask this question as it's own thread. I'll do the best I can to explain it. I'm going off what was on GMC Pauls page that I linked and some other stuff. But what that referred to was the old style ammeter took full power from the battery and that wire looped around to some kind of junction box and then to the battery. I do not have mine hooked up as that is the circuit that was burned up on the card. Which i'm pretty sure backfed into everything else or it burned up at the same thing everything else did. I'm not sure if that helps but it's what I have figured out from reading other threads and pages. -Jason
- Jason
Closed Thread
