Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 05-03-2018, 10:39 AM   #1
Roblenzz
66 K10 crossmember question
I have a long wheel base Factory four wheel drive truck with the divorced transfer case (has its own crossmember) and I am swapping in a NV4500 transmission. My question is do I need a third crossmember for the transmission or does the stock cast iron bellhousing crossmember sufficient to support the extra (25lbs or so) weight of the 5-speed? Thanks
Roblenzz is offline   Reply With Quote
Old 05-03-2018, 01:26 PM   #2
61K10
61K10's Avatar
Re: 66 K10 crossmember question
still in the wrong place lol. engine and drive train. you should be fine with the stock bell But.
No nv4500 will bolt up to it with out an adapter. do a search in the engine and drivetrain section.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-17-2018, 03:13 PM   #3
Roblenzz
Plan on modifying the NV case so I can maintain the mounts and the factory starter location on the bellhousing. I know they won't bolt up. Gonna fill and redrill the NV case. The throw out bearing glides as it should on the input retainer. The bellhousing even fit over the retainer without any machining. Do I need to use an additional crossmember for the tailhousing?
Old 05-29-2018, 12:08 PM   #4
dieseldude4bt
I think it will hold it fine.
I have had a ranger overdrive and an sm420 with a dual direction pto hanging off my bell housing for 18 years with no problems.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 07-01-2018, 07:28 PM   #5
whateverpratt
I hung an nv4500 off of my stock bellhousing with a custom adapter and no trans crossmember. I've abused it for years, and it's held just fine. Now, I don't know how well the bellhousing will hold when I swap the 350 for a 4bt, but we'll see
'66 c10 rust bucket, 350 (pulled and sold, now waiting on 4bt install) nv4500 stock bellhousing, '85 c30 front suspension and 3/4 rear coils with 4.10 H072 rear axle
NV4500 install http://67-72chevytrucks.com/vboard/s....php?p=6488778
Suspension update http://67-72chevytrucks.com/vboard/s....php?p=8236775
whateverpratt is offline   Reply With Quote
Old 07-30-2018, 04:29 PM   #6
dieseldude4bt
Mine has had the 4BT for 18 years.
Old 07-30-2018, 04:40 PM   #7
whateverpratt
Well crap, apparently you’ve already done what I’ve been planning.
So you used a 4bt with the Chevy bellhousing adapter from a bread van bolted to the stock bellhousing in the stock bellhousing cross member?
What did you use for your front motor mount(s)?
Do you have a build thread?
Old 08-01-2018, 09:23 PM   #8
dieseldude4bt
Yes on the chevy adapter and stock bellhousing and a ranger overdrive.
The bellhousing is in the stock position with stock mounts and I made two front mounts, but I would recommend one like chevy did on their early straight 6's. Four mounts keep the engine too rigid and transfer lot's of vibrations to the frame.
I had some pic's until photo bucket wanted $400 to let me post pic's then I cancelled my account.
Old 08-02-2018, 09:00 AM   #9
whateverpratt
That photo bucket fiasco messed up a lot of forums.
Thanks for the motor mount advice. My frame that the 4bt will be going into has the 235 front crossmember, so I'll plan on fabbing something to make that work.
