12-03-2007, 05:15 PM | #1 |
72 C10 with Cummins
Started this project because my wife needed something to drive She didnt want to buy she convinced me to just fix the 72 it needed a motor the small block that was in it was turbo charged need some pistons I had the 5.9cummins just sitting there.I just couldn,t resest putting in the 72 I had the adaptor to a 400th already and the nash overdrive was on the tranny.getting 21 mpg now city and Hwy with 3.90 geas order the 3.08 yesterday trying to get 25 to 30Mpg on the hwy the swap was on of the easest I ever done .
Dale [/IMG] [/IMG] [/IMG] [/IMG] [/IMG] [/IMG] Last edited by 2wpuller; 12-03-2007 at 11:58 PM. Reason: pic didn,t work |
12-03-2007, 11:01 PM | #2 |
Re: 72 C10 with Cummins
Pics didn't work Keep tryin I wanna see. I had thought about this same swap just about a week ago.
Albie |
12-04-2007, 12:11 AM | #3 |
I can,t get the pic to show they are in my gallery.
Dale |
12-05-2007, 01:37 AM | #4 |
There they are. Last edited by 1972CheyenneSuper; 12-05-2007 at 01:38 AM. |
12-05-2007, 02:25 AM | #5 |
Wow, you better keep that one!
Try to keep the truck too, the Cummins looks right at home there
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars |
12-05-2007, 10:02 AM | #6 |
Formerly yellow72custom
Wow, awesome....I bet it has a lot of power too!
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
12-05-2007, 11:30 AM | #7 |
Farm Truck
Is it in a Half ton truck?
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
12-05-2007, 04:11 PM | #8 |
Thanks 1972 CheyenneSuper how did you do that.
I don,t have her turned up very much YET waiting for the other turbo to get done and the time to put in the other Ijectors. It is a 1/2 ton it only setlled down 1.5 in in a month. She is a lot of fun to play with[the wife too]. Dale |
12-05-2007, 05:42 PM | #9 |
First you have to find the picture you want to display in your post. Right click on it and click properties.
Then highlight the URL of the picture and hit the Control key (ctrl) and the C key at the same time, this copies the highlighted text. Then go back to your post and select the yellow button with the gray mountains in it, and a window will pop up. Place your cursor in the box, click, and hit the Control key again but this time with the V key which pastes the text that you copied earlier, then hit ok and you're done! This works with nearly every picture on the internet, except those that are coded to prevent hotlinking as it's called. |
12-05-2007, 07:04 PM | #10 |
I coppied the url from my gallery. thanks again.
Dale |
12-19-2007, 06:32 AM | #11 |
Is there a faster blowing heater fan for the 72.s
Dale |
12-19-2007, 10:12 AM | #12 |
I have that exact motor in an 93 dodge thaT I want to put in a 67-72 Burb, did you use the Chev frame or the Dodge?
12-19-2007, 10:31 AM | #13 |
I used the stock chevy frame the swap was real easy.
Dale |
12-19-2007, 11:42 AM | #14 |
I don't know about a faster fan, but making sure the flap doors in the heater box move all the way to their stops can go a long way.
12-19-2007, 11:43 AM | #15 |
Any picts? I was going to do the dodge frame figuring everything was there and beefy enough to handle the diesel, setting a body over it wouldn't be hard, but if the motor install is easy then I'll keep looking for a 4X sub and just slide the motor in there!! PICTS PLEASE of the install and any progress picts while you were doing it?
12-20-2007, 03:32 PM | #16 |
We took the turboed charged smallblock out and the 5 sp 2hr later the 5.9 and the 400th was sitting down in the frame.Didn,t have time to take any install pic. will try to use my buddys lift to take some pic from underneath.tae the exhaust manifold off and turn it upside down the turbo will clear the heater box just fine as you can see.
I,ll Pm you my phone no. Dale |
12-20-2007, 05:51 PM | #17 |
That is great! I have heard of doing this and thought it would be a great set up for a tow vehical or heck with 20+mpg a DD.
Kevin LFD inc. |
12-21-2007, 09:58 AM | #18 |
I've got a '71 LWB with a body in pretty nice shape but the trans leaks and the engine's pretty tired. I also have a '991 QC 4x4 Cummins that I love so I've had this kind of swap in mind for a while, now. The thing I'm debating on is whether to go 2wd or 4x4. If I go 2wd, I'd just need to round up a 12-valver and an NV4500. If I go 4x4, I'm looking for a complete Dodge 94-98 that I can just do a body swap on. I'd love to see more pics of this conversion to help me decide which way I want to go. What'd you have to do to the front suspension to beef it up? I mean, these friggin Cummins weigh close to 1,000 lbs. and I'm thinking the 350 tops out at, what? 3-400 lbs.?
What did you do for motor mounts? Accessory brackets? |
12-22-2007, 01:10 PM | #19 |
The 350 is at 500lb.When I was in my hotrod days we put in a 454 with a 1271 blower with a pair of850 holley carbs and aircon, and a 400th. the front dropped almost 2" this one with the cummins has only droped 1.5" in almost 2 months the front sus, is all stock handles sweet.I have a 33gal.gas tank out of a sub, and the big batt, are mounted back by the tailgate one on eachside launches from a stop sighn hard. we get alot of looks at red lights.it is alot of fun when a guy roles his window down just to hear the noise.one person eaven got out of his car to tell me that my motor has a rod going out said he was a mechanic at a chevy dealer in the St.Louis I just laughed and told him what it was he just gave me a blank look as I drove off.
Dale |
12-22-2007, 08:08 PM | #20 | |
'You know your car sounds like its about to blow up?' 'Do you have oil in that thing?' and stuff like that pretty often.
12-23-2007, 06:26 AM | #21 |
I just picked up a diesel power mag and low and behold a 12 valve hop up article in it. I want some smack down. I have a 2wd NV 4500 that I am considering a 205 and the Chevy 3/4 ton axles I have. I wanted to find a nice 90's 4X4 Dodge and just do the body swap, but beggars can't be choosey, this deal came along and I couldn't pass it up. As it seems the Chev frame will make converting to 4X4 easier. Dale, I'll give you a call when this project starts moving, as of now I am driving the dually!!
12-23-2007, 07:16 AM | #22 |
PISS POOR
Did I understand you when you said that the turbo was the one from the small block?
Ive found a 94 4wd dodge cummins that I want to do a body swap on for 4k. I would like too keep my truck as low as possible though, so this seems like a good idea! (its almost dragging frame right now) What did that 12v cost you?
Slammed 67 long bed with vette suspention build thread http://67-72chevytrucks.com/vboard/s...d.php?t=291149 Last edited by turbohacker; 12-23-2007 at 07:17 AM. |
12-23-2007, 08:06 PM | #23 |
The turbo is off a 96 cummins the one one that was on the 350 was a H2E of a L10 cummins.
My brother and I bout a93 and a 96 one was wrecked the other was burnt got them boothe for 1500.00 the 93 was 4x4 sold most of the parts still have the 96 duelly bed.the 96 motor is being used for our 2wd supermod pulling truck. Dale |
12-23-2007, 08:25 PM | #24 |
Dale are these engine's EFI or MFI? What all is involved in the hook up and I assume the Dodges also came with AOD's right? Are they any good for a 2wd tow vehical? Thanks for any info you might have.
Kevin LFD Inc. Last edited by Rokcrln; 12-23-2007 at 08:27 PM. |
12-25-2007, 09:32 PM | #25 | |
All the Cummins Engines are direct injected diesel fuel into the combustion chamber.
Up to 1988 1/2, the fuel system is mechanically controlled, needing only power to the injection pump to run. Newer trucks use a computer. In factory form most need a tach signal, or they shut down. Dodges come with a weaker Getrag 5 speed, stronger NV4500, or even stronger NV5600 or a 4 speed auto that has the same issues as all work truck autos. Grumman GM step vans have a 4 cyl version of the same motor, and use a TH400 or SM465. 96-98 3/4 ton Diesel Dodges with a stick shift can get 25+ MPG, and put out Quote:
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars Last edited by 68K20 x Drill; 12-25-2007 at 09:32 PM. |
