Old 02-09-2009, 03:01 PM   #1
cod9939
1978 Chevy Silverado - Dual Tank Switch
Hello,
My nephew just bought a 1978 Chevy Silverado truck with dual gas tanks. The in dash switch to select which tank to use is disconnected. The switch has a short 'wiring harness' physically connected to it approximately 18 inches long and a plug on the end of the wiring harness. That plug is not connected to anything and I looked behind the dash and cannot find where this plug for the switch should be connected? Does anyone have suggestions on where the switch should be connected??
Also, the fuel gauge is not working, the needle is pegged all they way to the right and does not move. Is this related to the gas tank switch being disconnected, or is the fuel gauge a seperate problem?
Thanks!!! Charles
cod9939 is offline   Reply With Quote
Old 02-09-2009, 07:09 PM   #2
westie 666
westie 666's Avatar
Re: 1978 Chevy Silverado - Dual Tank Switch
I would think that as the tank select switch forms part of the fuel gauge circuit that once it is disconnected there will be no reading on the gauge : IE if you select the left tank the gauge reads the left tank and the same for the right tank.
Sorry I can't help as to where plug goes as my truck is at the doctors, I'm sure some one will be able to help.
77 Cheyenne no longer in bits
westie 666 is offline   Reply With Quote
