01-17-2010, 11:52 PM | #1 |
Flat-Tappet Cam-compatible Oils * thread no longer updated by OP*
The information below represents a list of oils that claim or have verified the appropriate (1,000-1,400 PPM) amount of ZDDP. At the bottom of the list are break-in oils.
Amsoil Synthetic Premium Protection Available via Forum Vendor C66 Racing LLC; PM 'Subdriver' for more information Grades: 10W40 (AMO), 20W50 (ARO), 5W20 (HDD), 20W-50 (TRO) Brad Penn Grades: 0W-30, 10W-30, 10W-40 , 15W-40, 20W-50 Castrol Syntec 20W-50 Grades: 20W50 Collector's Choice Motor Oil Grades: 20W50 Joe Gibbs Hot Rod Oil Grades: 10W30, 15W50 Mobile 1 15W-50 Grades: 15W50 Red Line Synthetic Motor Oil Grades: 0W20, 5W20, 0W30, 5W30,10W30, 0W40,5W40,10W40,15W50,20W50 Royal Purple RP Grades: 10W40, 15W40, 20W50 Royal Purple XPR Grades:0W10, 5W20, 5W30, 10W40, 20W50 Valvoline VR1 Grades: 20W50, 10W30 Valvoline Specialty Racing Oil ("Not Street Legal") Grades: 20W50 Valvoline Roush Full Synthetic Grades: 5W30, 5W50, 10W30, 10W40 Valvoline Racing Synthetic Grades: 20W50, 10W30 Engine Break-In Oils/Additives Brad Penn Break-in Oil CompCams Break-in Oil GM Engine Oil Suppliment (EOS) Joe Gibbs Break-in Oil Royal Purple Break-In Oil Last edited by Liz; 06-29-2011 at 07:49 PM. Reason: Not needed comment removed |
01-18-2010, 12:06 AM | #2 |
Right on the line, baby!
Re: Flat-Tappet Cam-compatible Oils
I know we recently went through this subject, but wanted to make it easier to read, so if anyone has recommendations for good flat-tappet oil, please post it to this thread.
Thank you-
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly Click and scroll down for site vendors! Subscribe here! |
01-18-2010, 12:47 AM | #3 |
Nice post Ticker!!
I was actually wondering about this issue for older Datsuns, with my previous truck being an 1973 Datsun 620. The American V8 crowd, and the way those engines are built IS important regarding this issue. I can only speak for a Nissan L20B, which I had in my '73 Datsun 620, but that engine has NO resemblance whatsoever in the valvetrain to a PUSHROD operated hydraulic or solid lifter camshaft. This is important because the hydraulic pushrod V8's are pretty tough on cams, as are solid lifter V8's, simply by the way the whole shebang is layed out. There is very little if any real valve clearance in many of those engines, obviously because the pushrods constantly ride the lobes of the camshaft. That is in contrast to something like an L engine, which actually has a spec for clearance between the cam lobe and "rocker". First, if you have a newer catalytic converter, your catalytic converter WILL die if you use diesel oil or too much ZDDP. If you don't have a cat, then I don't see what it could hurt to use the additive. You can also go down to WalMart and buy Chevron Delo LE, which has enough zddp for pushrod V8 engines right out of the bottle. Actually, from what I've read, DELO is the ONLY real diesel oil that DOES meet the .12 Zinc spec. Rotella is NOT worth using anymore. I've found that most of the diesel oils are going away from putting Zinc and Phosphorous ( ZDDP) in the mix for emissions reasons. If you don't have a cat, the additive certainly couldn't hurt in the right quantity. I'd run the DELO in my truck since I don't have a cat. I'd run it only to be on the safe side, NOT because I thought it would be the difference between life and death for the valvetrain. BTW- I'm talking about the oil we run all the time, not for breaking in rebuilt engines. GM has a great additive called EOS for that purpose. On another note, after doing some research, the STP four cylinder oil treatment (in the red bottle) has more than the required amount in PPM of ZDDP when mixed with five qts. of oil. It will bring the level of ZDDP at least to where it was back when our engines were new. So using any oil and putting in one bottle of the STP four cylinder treatment should be enough to prevent excessive cam wear. Hope that is helpfull!
Thanks, Aaron Life is about making dreams come true, stop dreaming and make life happen. 64 GMC Project MY_YOUTUBE_VIDEOS To keep an opened mind- speculation is devine. Assumptions always lead to a dead end! Last edited by Phlebmaster; 01-18-2010 at 12:58 AM. |
01-18-2010, 01:09 AM | #4 |
Thanks, I hope it's useful.
I have to question the Chevron Delo LE recommendation - Virgin Oil Analysis (VOA) shows ~1000 ppm Zinc and ~900 ppm phosphorus, and it's specifically listed as API CJ-4...which as noted above means it can't have enough ZDDP for a flat tappet cam (> 1200 ppm). http://bobistheoilguy.com/forums/ubb...73#Post1633073. Do you have different information from another source? Also as noted every single oil vendor will recommend that you NOT use an additive on a regular basis - partially for exactly the reason you note (catcons) but also that too much creates deposits in the combustion chamber. Last edited by Ticker; 01-18-2010 at 01:11 AM. |
01-18-2010, 01:14 AM | #5 | |
Thanks, Aaron Life is about making dreams come true, stop dreaming and make life happen. 64 GMC Project MY_YOUTUBE_VIDEOS To keep an opened mind- speculation is devine. Assumptions always lead to a dead end! |
01-18-2010, 07:53 AM | #6 |
The lack of zinc in modern motor oils has been a highly discussed topic on the Buick Grand National discussion boards. Most guys use regular conventional oil w/ 1 little bottle of ZDDPlus at every oil change. ZDDPlus is available on ebay. About a year ago, I read that GM changed the formula for its EOS additive.
I personally use Amsoil- but it's very expensive. Amsoil's 10W-40 and its racing oil have enough zinc in them that there is no need to add more zinc. Dont know how true it is but Amsoil claims to be the first Syntethic. There are other good oil choices but i have always liked Amsoil. Good luck. Last edited by 2badgn; 01-18-2010 at 07:56 AM. |
01-30-2010, 10:35 PM | #7 |
Valvoline VR1 contains ZDDP and is available at most local part stores.
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 01-30-2010 at 10:36 PM. |
01-31-2010, 12:25 AM | #8 |
VR1 is a racing oil and not really appropriate for street use - which is why I specifically excluded it. Virtually all of the racing oils will have 1500+ ppm ZDDP.
02-02-2010, 06:06 PM | #9 |
I use valvoline vv855 not for street use but has 2300 ppm zinc and is found at most napa stores behind the counter . This is a 20 w 50 full syn. if your running a wild flat tappet cam.
02-05-2010, 02:32 PM | #10 |
so is rotella good? thats what i have been running without zinc additives and i keep hearing it used to be good but now its not anymore either?
1970 GMC- 454 DONT GIVE ME NO JIBBA JABBA!!! |
02-05-2010, 02:50 PM | #11 |
As an ILSAC CJ-4 spec oil, it must have less than 1200 ppm ZDDP. Oil analysis typically shows in the 800-1000 range - not enough per cam manufacturer's recommendations.
02-08-2010, 12:56 AM | #12 |
Andy
I run Valvoline VR1 10w30 with a k&n filter in my street driven 406 as per the engine builder's recommendations.
"Valvoline VR-1 Racing Motor Oil is recommended for engines burning gasoline and full or partial alcohol fuels in track and street service." Quote taken directly from the Valvoline document in the link below. http://www.valvoline.com/pdf/VR-1_Racing_Motor_Oil.pdf
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi 1969 CST/10 383|Aisin AR5 5 speed 1972 K5 350|Turbo 350 4x4 2005 Duramax 2500HD 4x4 |
02-09-2010, 04:56 AM | #13 |
Talking about filters brings up oil. As i said my father and his brother were SCCA racers from before I was born to the late 70s, mostly B Prod Corvettes, and they built their own engines. ((I was raised to never call a rifle a GUN and never call an internal combustion engine a MOTOR, although I never had to do the Marine "this is my...." bit..)) The books said use AD Aeroshell and since both were pilots, they did. AFAIK both Shell and Chevron piston engine aircraft engine oils have not changed a bit in 50+ years due to the static nature of general aviation technology.
I used Aeroshell in VW and Corvair engines and lawn mowers and in the Screaming Jimmy two cycle in the old tow rig, and never had a problem. The oil companies say you should never, never, never do this, but we did, and those road race engines ran moderately tuff cam profiles. The Chevy Power books said it was okay for a long time too. I'm not saying you should do this. But it worked for us, worked great. |
02-09-2010, 10:52 AM | #14 | |
As I pilot, I can tell you that aviation oils are far different than engine oil. The engines are VERY different, with very low HP/CID typically running at very low RPM (< 3000) for hours on end. They're also changed every 25 hours or less. |
02-09-2010, 12:36 PM | #15 |
I am just about to drain the break in oil out of my 454 i used non detergent 30 wt and the lucas cam break in additive until i read this i was planning on just adding some of the additive with each oil change but some one mentioned build up by doing that.not sure what to do now.what about shaffer synthetic oil ?does it have the zink or does it not need it because it is synthetic? because i know some people that swear by that stuff and they use it in everything from combines, to racecars, to machine tools.
02-09-2010, 12:50 PM | #16 |
Virtually all of the oil companies recommend against using an additive on a regular basis.
Kinda hard to tell with the Shaffer stuff; lots of claims but I din't see anything specifically stating their ZDDP levels. They say it "exceeds" API SM, which if true could mean they have more than the API SM required amount of phosphorus. I found one oil analysis out there which seems to indicate they are too low in ZDDP with 856 Phosphorus and 1047 Zinc, and another one on the same thread with about the same results: http://www.bobistheoilguy.com/forums...&Number=961160 Based on those numbers, I would personally pass. Stick with the oils listed at the top and you'll be fine. Last edited by Ticker; 02-09-2010 at 12:51 PM. |
02-09-2010, 07:02 PM | #17 |
well i just got off of the phone with shell and they told me that the rotella still contains 1,200 parts per million ZDDP, (it used to be 1400) so i should be able to use this with no additives which people seem to be advising against and not have any issues at all. i am running the cf-4 sae 30w not a cj-4 spec oil.
1970 GMC- 454 DONT GIVE ME NO JIBBA JABBA!!! Last edited by lovnthe70; 02-09-2010 at 07:05 PM. |
02-09-2010, 08:28 PM | #18 | |
My guidance is still that it's not a good selection overall; if the straight 30W works for you, all good |
02-10-2010, 03:48 AM | #19 |
I just got off the phone with one of the guys my father raced with. He said the reason the oil companies absolutely refuse to recommend any "Aircraft" product for non aviation applications is that the lawyers have told them they must not as part of their liability strategy. It's so bad that they have a separate line of turbine engine synthetic oils for "aeroderivative" ground and marine turbine engine users that are actually identical, with a different name. Since there are several different types of synthetic turbine engine oils that are peculiar to one type or class of turbine engine, they have to duplicate the whole range, pretty much, with another label. They dye the oil a different color is the ONLY difference between the oil recommended for a P&W PT-6A and the ground version, the ST-6.
He said he still runs AD aircraft oil in his flat twin BMW motorcycle and in his Corvairs and the big block in his ski boat. He did say something interesting though: If an engine with older types of oil seals has been run for several years with regular oils, using Aeroshell may start leaks. It seems Aeroshell contains bentonite, which is a fine clay! He recommended Chevron brand instead because it does not do this, except in fairly fresh engines because Aeroshell is a lot easier to find. New oil seals tolerate bentonite and "get used to it" but if they are older it is rough on them. Our (two cycle DD powered) truck did leak a lot of oil, but we thought that was just normal for Detroits. It turns out they are not supposed to LEAK oil, they-as he puts it-"plenumstrate". The inside-the-block air chambers, called a plenum, condense out the oil vapors and collect them on the walls, then when the engine shuts down, they run off as a watery sludge--mess. It's been twenty years since I've even seen that truck, and the Detroits are mostly gone from the roads except in a few old tour buses and fire engines. But as much as I drove that old beast and fooled with it, I never knew that. |
02-11-2010, 09:18 PM | #20 |
I haven't seen anyone here mention Brad-Penn. I've never seen a half synthetic oil before but its got good zinc levels:
http://www.bradpennracing.com/Zinc.aspx |
02-12-2010, 12:16 PM | #21 |
Brad Penn consistently falls well under their claimed 1500 ppm ZDDP during analysis, typically showing around 800 ppm Phosphorus and 1100 Zinc. There's been some discussion that there was an "old" formulation and a "new" formulation, but I still haven't seen a VOA anywhere near what they claim. I got in a Hell of a lot of trouble over this elsewhere...but I'm still waiting for a VOA that shows 1500 PPM ZDDP
It's really tough sometimes to sort this stuff out - there are the manufacturer's claims, then there's oil analysis...I listed the oils that consistently back up their claims with independent oil analysis. |
02-12-2010, 09:08 PM | #22 | |
In kind of an aside are there other half synthetics out there? Its kind of weird I thought you had to be either 100% synthetic or 100% dino oil rather than a combo of both. Last edited by turbo350; 02-12-2010 at 09:09 PM. |
02-13-2010, 12:13 PM | #23 |
I'm just an agnostic When a manufacturer claims ZDDP levels, I call them to get their claim, and then look around for an oil analysis - or send one off myself - to see if the numbers match up.
Overall the best advice I can give is test your oil! It's cheap to do, and it will tell for sure what level of ZDDP is present. http://www.blackstone-labs.com/free-test-kits.php There are all kinds of synthetic/mineral mixes out there; I'll look for a link that gives better information, but they're denoted by Group I to I think Group IV; here's a bit of background: http://en.wikipedia.org/wiki/Synthetic_oil Last edited by Ticker; 02-13-2010 at 12:16 PM. |
04-01-2010, 12:22 AM | #24 |
anyone tested Royal Purple? just got some HP 10W-40. Im guessing based on Tickers 1st post this oil is fine for Flat Tappet. Only running a 540 lift so not to crazy.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
04-01-2010, 01:03 AM | #25 |
RP consistently comes up over 1200 ppm; XRP typically over 1400 ppm.
I have RP and Valvoline VR-1 out to Blackstone. I recently recieved my Brad Penn 10W-30 test: Phosphorus: 1026 Zinc: 1300 Just under 1200 ppm, but well under the 1500 ppm claimed. Other tests were closer to 1100 zinc, 900 phos - indicating some real quality control issues at Brad Penn. Last edited by Ticker; 04-01-2010 at 01:06 AM. |
