02-25-2010, 02:54 AM | #1 |
Does anyone make a 5x4.75 rotor for c10
Does anyone make a 5x4.75 rotor for c10 yet i seen where people use rotors calipers and lines from a camaro or redrilling but really just curious about a simple replacement one
70 SWB STEPSIDE 70 BLAZER 09 challenger |
02-25-2010, 08:35 AM | #2 |
67-72 parts collector,…
Re: Does anyone make a 5x4.75 rotor for c10
02-25-2010, 09:20 AM | #3 |
vw guy & now c-10 guy
cpp does too.
02-25-2010, 10:38 AM | #4 |
Thanks both of you
03-11-2010, 08:41 PM | #5 |
Are these rotors available for 73-87 trucks? If so, what about rear discs?
First and Foremost: Thank you God for my Salvation! I pray that others will seek your Son, Jesus Christ! My 63 Double Dropmember Build "Project Sub-Zero": http://67-72chevytrucks.com/vboard/s...42#post5050342 My 2013 Camaro 1LE: https://www.youtube.com/channel/UCxa...wL5d6RnmfdJa1A 86 C10 "Build Thread”: http://67-72chevytrucks.com/vboard/s...d.php?t=668777
03-11-2010, 10:44 PM | #6 | |
As far as the rear disc rotors,... I would check the two compaines listed above. Both have websites.
03-12-2010, 09:16 AM | #7 |
Won't fit: mine is an 86 with the 1" thick rotors.
03-12-2010, 10:11 AM | #8 |
Happy to be here
Then you will need to change spindles, bearings, etc or change your choice of wheels.
03-12-2010, 07:28 PM | #9 |
Active Member
The CPP Modular drop spindle and 13" brake kit can be made for any bolt pattern. We also have a conversion kit for drum brake spindles that uses a car 5 on 4-3/4 bolt pattern. We can only do the rear disc as 5 on 4-3/4 with a 12" rotor.
Danny Nix CPP |
