Old 01-25-2011, 01:09 AM   #1
Your41Plague12
Your41Plague12's Avatar
Angry Wiring Woes
Ok guys, I have two separate issues, and I'm hoping someone can enlighten me. The search turned up no results. I just swapped in an 83-84 grille, and now my left turn signal only works when my headlights are off. When the headlights are on, the turn signal in the grille will not flash. It doesn't get dimmer or brighter. The side marker does work though. When the headlights are off, it works fine. The 4-ways work fine with the headlights on and off. I didn't change the wiring at all, and it worked fine with my old (86) grille. I'm stumped on this one. My second issue is even more ridiculous. When I have my 4-ways on and I press the brake pedal, the 4-ways go solid. I imagine the wiring is crossed somewhere between the two, but I'm not sure. Keep in mind, this truck has been so frankensteined together over the years that almost nothing is original. The wiring has been completely butchered by a multitude of people, and I'm just trying to bring it back to 100% working order. It's just difficult to work around other people's previous mistakes. Any ideas? Thanks guys.
Steve
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 01-25-2011, 03:36 AM   #2
hatzie
Moderator
hatzie's Avatar
Re: Wiring Woes
Check the ground connections on the radiator support.
Old 01-25-2011, 10:26 AM   #3
Jonboy
Slots go on anything!
Re: Wiring Woes
There should be one on each side, right behind the headlights. Definitely sounds like a ground issue.
1974 Jimmy- 5.3/4L80e/NP241
Old 01-25-2011, 11:02 AM   #4
ironroad9c1
Master Hater
Re: Wiring Woes
clean the paint from under the ground screws real good and wire brush the ground lugs and screws.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42
"This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors
ironroad9c1 is offline   Reply With Quote
Old 01-25-2011, 11:40 AM   #5
dropd80s
dropd80s's Avatar
Re: Wiring Woes
When you have your 4 ways on and you hit the brakes, they are supposed to go solid so someone can see if you are stopping.
dropd80s is offline   Reply With Quote
Old 01-25-2011, 05:15 PM   #6
ont_guy_38
ont_guy_38's Avatar
Re: Wiring Woes
Exactly
ont_guy_38 is offline   Reply With Quote
Old 01-27-2011, 05:15 PM   #7
Your41Plague12
Re: Wiring Woes
D'oh! I should have known that. I'm so used to looking at the back of the newer cars/trucks with separate turn signal assemblies that keep blinking independently of what the brake lights are doing. Thanks for the help guys, much appreciated.
Steve
Old 01-27-2011, 09:40 PM   #8
datguysaL
Re: Wiring Woes
make sure your using regular bulbs. if your using the LED lights, then that could be your problem. i switchd to LED and they gave me hell, i just went old school and tossed the new stuff.
datguysaL is offline   Reply With Quote
Old 01-28-2011, 10:47 PM   #9
Your41Plague12
Re: Wiring Woes
Nope, no LED bulbs here. Regular 1157A's. Where are these grounds on my rad support, behind my grille or on the other side, like by my radiator on the engine compartment side?
Steve
Old 01-29-2011, 03:20 AM   #10
JuicyJ
JuicyJ's Avatar
Re: Wiring Woes
Your grounds should be on the engine side.
America is all about speed, hot nasty bad ass speed
JuicyJ is offline   Reply With Quote
4 ways, flashers, headlights, turn signals, wiring
