07-28-2009, 12:09 PM | #26 |
Tot Roddin'
Re: DO NOT OPEN- Air Ride Technologies inside
And to think... I was just about to ask what tire sizes you were running.
Are you happy with the KDW's?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
07-28-2009, 08:19 PM | #27 |
Happy to be here
That's the current set up. I have been considering a fresh look. As for the KDW's they are just fine. When I bought them, they were very pricey but it was the only matching tread pattern I could find.
The price has dropped on them over time as well as there are more economical alternatives. Some times it cost extra to be anal...
07-28-2009, 09:42 PM | #28 |
>130dB Moderator
It always costs extra to be anal. Always.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
07-31-2009, 07:22 PM | #29 |
Happy to be here
Re: Finally! My Cheyenne is back on the road.
Sneak peak! Bed off...
07-31-2009, 11:56 PM | #30 |
67-72 parts collector,…
subscribing to this one,...
08-02-2009, 04:38 PM | #31 |
Happy to be here
Re: What did you get done 8/02/09 edition
I personally didn't get much done this week besides a lot of research. There are several things I am considering as upgrades on my 77 that needed to be looked in to. Still looking for answers there.
On the other hand my buddies Keith and Roger where a blur of progress on my truck. By mid day on Friday they had the front suspension changed out. They moved so quickly, I didn't get a progress report until the wheels were back on. What you don't see is the stock A-arms have been replaced with a complete set of ART Strong Arms and an ART heavy duty Musclebar kit. Before and after-
08-02-2009, 04:42 PM | #32 |
Happy to be here
On Saturday they moved to the rear. The bed came off and tear down began. The frame rails were stripped of the leaf spring hangers in preparation for the ART Airbar 4 link system.
08-02-2009, 04:48 PM | #33 |
Happy to be here
The front 4 link brackets mounted in the existing holes. The restr of the assembly bolted to the axle. Unfortunately the original C-Notch with boxing plates had to be removed. That required 18 holes to be drilled to install the new C-notch.
08-02-2009, 04:54 PM | #34 |
Happy to be here
The existing mounting points for the tank rack were saved. The exhaust system will probably need to be modified. The wrong panhard bar bracket was sent with the kit so the panhard bar couldn't be installed to check for clearance.
While I didn't get a lot done Keith and Roger had a very active weekend. Thanks to my buddies for moving forward. Special thanks to Roger at RPL Customs for making room in his very hectic schedule to take this project on.
08-04-2009, 04:34 PM | #35 |
I'm just glad to be here!
Looking good, its great to have buddies like you have in Keith and Roger.
Care to let us in on the other updates your thinking of? Given how the truck has been in the past, anything that you decide will be top notch...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
08-18-2009, 10:07 AM | #36 |
Low & Fast!
Any updates Ken?
08-18-2009, 10:14 AM | #37 |
Happy to be here
I am going to pick it up on Sunday. I got the latest round of cell phone pics yesterday. They got the correct panhard bar bracket installed. ART had shipped a 10 bolt bracket and my 77 is a 12 bolt. They finished plumbing the airlines, and rerouted the rear brake lines. With the addition of a new pressure switch to replace a flaky one, I should be ready to roll.
08-18-2009, 10:16 AM | #38 |
Happy to be here
It's not easy to tell from the pics, but it sits a little lower all around. The front was raised back up with the addition of a custom built bump stop to allow it to roll. The rear is probably just a bit lower than the front, so a taller stop will be added there too.
08-18-2009, 10:20 AM | #39 |
Happy to be here
The exhaust will need to be modified. I had it running down the drivers side and out the back corner. With the crossbrace, shock, and panhard bar all occupying that space now, it won't clear. I plan to cut and flip the Y-pipe and run down the passenger side.
08-18-2009, 10:25 AM | #40 | |
Happy to be here
Like everyone else, I have my wish list. I am considering several options such as new wheels, and bigger brakes. More than anything, I would like to get my bucket seats recovered and installed. I finally located the correct vinyl, so I am one step closer to that happening.
08-18-2009, 01:32 PM | #41 |
Tot Roddin'
Ken, that thing has turned out amazing, and I can definitely tell a difference in the stance of your truck.
Can't wait to see some shots of it back on the prowl... awesome work Roger and Keith!
08-18-2009, 01:35 PM | #42 |
On the fast track to nowhere..
Looks good Ken. That is such a clean truck.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
08-19-2009, 11:56 PM | #43 |
Happy to be here
All done and ready to come home. I am going up Saturday to pick it up...
08-20-2009, 07:49 AM | #44 |
Tot Roddin'
Man that thing looks good! And I thought it sat just right before... it looks even better now.
Congrats Ken!
08-20-2009, 09:35 AM | #45 |
It doesn't get any better than that, but you're welcome to prove me wrong
08-24-2009, 01:09 PM | #46 |
Low & Fast!
Looks killer Ken, let us know how it rides..
08-24-2009, 01:15 PM | #47 |
WOW
color me GREEN with envy!! So whatcha doing with you old rear parts? Sleeve bag set up and shackles mainly?
CHEVY ONLY |
08-30-2009, 01:14 PM | #48 |
Happy to be here
Install story is finished- LINK
08-30-2009, 01:19 PM | #49 |
i love your truck, its just so perfect its un real!
i remember when we did the "buy in" for ART, it was nuts all the pallets of boxes. we spend days goiin through parts and kits. |
08-30-2009, 09:02 PM | #50 |
very nice write-up Ken. truck looks amazing w/ that extra amount of drop. cant wait for the road test write-up!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
Thread Tools | |
Display Modes | |
