05-31-2011, 10:05 PM | #1 |
Drag Racer
mini starters
hey guys i lost the starter in my C10 this last weekend and want to replace it with a high torque mini starter. Who has one of the better brands of mini starters out there and what model should i get. theres so many to choose from and i have NO CLUE which one to go after. please let me know.
Zach Hall 1983 Chevy C10 R/T: .194 60': 2.322 330: 6.379 1/8: 9.803 MPH: 71.37 1000: 12.781 1/4: 15.314 MPH: 88.79 |
06-02-2011, 11:24 AM | #2 | |
*** That's interesting ***
Re: mini starters
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... Last edited by storm9c1; 06-02-2011 at 11:29 AM. |
06-02-2011, 11:34 AM | #3 |
~Rest In Peace~
Re: mini starters
get your self a msd starter or mean green starter http://www.4x4connection.com/prodsearch/mean-green.htm
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
06-02-2011, 12:35 PM | #4 |
Re: mini starters
i've used speedway motors branded starters for many years not ever a problem with any that i've used
chrome starters seem to start best
06-03-2011, 06:59 AM | #5 |
Re: mini starters
I am running a Hitachi mini starter that I purchased at Summit... had it on the truck almost two years and no problems yet.
1990 S10 Reg. cab 2wd 2.5/ 700r4, lowered, soon to be a TBI 350/ 700r4 1993 2500 Reg. cab 4wd 6.5 turbo diesel/ 5spd, bigger turbo, Bull Moose pump, cold air intake, and a few other mods 1969 C10 Reg. cab 2wd 305/350, RHS heads, Voodoo Cam, Gilmer drive, 2400 stall, and lots of other goodies! |
06-03-2011, 01:33 PM | #6 |
Re: mini starters
I switched to a CVR mini starter a couple years ago in mine since I kept on having to rebuild the old gm high torque starters. Haven't had the first problem out of it.
1970 Chevrolet C-10 w/355sbc 2010 Silverado Daily Driver 1971 Mercedes 280sl project car |
06-03-2011, 08:18 PM | #7 | |
Re: mini starters
06-03-2011, 08:36 PM | #8 |
Moderator
Re: mini starters
Powermaster all the way. Made in USA, zero problems. Call their tech support line and Brady will tell you which one you need for your application.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
06-05-2011, 11:40 AM | #9 |
Drag Racer
Re: mini starters
how would i know which flywheel i have?
06-05-2011, 02:42 PM | #10 |
Re: mini starters
Sounds like it is time to count teeth.
06-05-2011, 03:51 PM | #11 |
Re: mini starters
Don't you also need special bolts for these newer starters?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
06-05-2011, 06:37 PM | #12 |
Re: mini starters
If the starter bolts are straight across you have a small 153 tooth flexplate.
If they are staggered you have a large 168 tooth flexplate. Most of the time trucks use a "large" flexplate. Last edited by clinebarger; 06-05-2011 at 06:37 PM. |
06-05-2011, 07:39 PM | #13 | |
At the body shop.
Re: mini starters
one on a vortec 454 the other on my 406 sbc Posted via Mobile Device
" That didnt make it any newer " " Dont antique the equipment " |
06-06-2011, 12:17 AM | #14 |
Drag Racer
Re: mini starters
well heres what i went with guys.....works for both 153 and 168 tooth flywheels
http://www.jegs.com/i/CSR/170/100P/10002/-1
06-06-2011, 01:47 AM | #15 |
Re: mini starters
I really want to convert over to the gear reduction type starter on my '65 but have been told that it wont work with my bellhousing that current starter bolts to.
06-06-2011, 10:48 PM | #16 |
Drag Racer
Re: mini starters
you can get OEM appearing gear reduction starters.....you just have to find the right one
06-07-2011, 03:50 AM | #17 | |
Re: mini starters
06-07-2011, 01:54 PM | #18 |
Re: mini starters
I posted this pic in another thread that I started involving my flexplate. But I wanted to follow up here about the starter. For a 168-tooth flywheel/flexplate, this starter will work perfectly on a SBC (and maybe big blocks too). Note the "L" bolt pattern that is the same for just about every SBC ever made.
186-tooth version: 8.1L 2003 Yukon or Silverado. L-pattern bolts. Advance PN 17420 153-tooth version: 5.7L 1995 Corvette. straight-pattern bolts. Advance PN 17124 Either one costs around $118 as of today with a lifetime warranty. You might need different bolts, but so far I've been able to reuse my stock bolts on all of the 153-tooth applications that I've tried (and I've done many). YMMV. The starter is on the left side of this pic. It is super light but packs a punch. Disregard the flexplate and other parts in the pic (was for my other post; has nothing to do with this thread).
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... Last edited by storm9c1; 06-07-2011 at 02:00 PM. |
06-07-2011, 11:17 PM | #19 |
Drag Racer
Re: mini starters
ok guys, one last question.,..since the starter i got is for both 153 and 168 tooth flywheels does that also mean it has provisions or adapters for both staggered and straight mounting options?
06-07-2011, 11:38 PM | #20 | |
Re: mini starters
Normally the 153 setup uses the straight row bolt pattern. And the 168 uses the L pattern on the engine pad. The universal ones just move side to side in the 153 tooth holes depending on what flywheel/flexplate you have. Since you would have to move the starter over about 3/4" outward for a 168, there might be rare cases when it won't clear tight headers or the bellhousing cover plate hole properly, etc. YMMV. If you have a 168 and it doesn't clear something, then get a L pattern version like I posted above. But be sure you have the 3rd boss for the L pattern starter. Most motors do. But some don't. Oh, and the gear teeth spacing is the same. Just a smaller diameter flywheel/flexplate, thus less teeth.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... Last edited by storm9c1; 06-07-2011 at 11:40 PM. |
03-22-2016, 06:48 PM | #21 |
Re: mini starters
I know this is a very old post but in case someone is interested in helping I am having an issue. I upgraded to the 186-tooth version: 8.1L 2003 Yukon or Silverado. L-pattern bolts from Advance Auto Parts - PN 17420. The problem is my headers are in the way. Those of you who this worked for did you have headers or an exhaust manifold? Any ideas what would work for a '71 SBC 350 with headers?
03-22-2016, 06:59 PM | #22 |
Re: mini starters
Yeah, 17420 won't clear headers and even some stock exhaust systems. You have to try it first and be prepared to take it back.
For your application (headers), I recommend Jegs 10081 for 186-tooth flexplate/flywheels. It's the same Nippon Denso design but can be adjusted to sit closer to the pan. It's more expensive but it works great and is super strong. http://www.jegs.com/i/JEGS+Performan...10081/10002/-1 Another option is Jegs 10080. This one can be used with both 153 and 168 tooth flexplate/flywheels. It's a little cheaper. But doesn't sit as close to the pan because you need to use the other set of holes that pushes it out. But it is more clockable, so that makes up for it. Its not as strong, but still formidable. http://www.jegs.com/i/JEGS+Performan...10080/10002/-1 Be prepared to switch the solenoid wire ring terminal to a spade terminal with either of those starters.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
01-28-2018, 07:22 PM | #23 |
Re: mini starters
im running the OG inline 6 engine with a turbo 350 trans. will the 95' Corvette starter do just fine?
02-01-2018, 02:43 PM | #24 |
Re: mini starters
Inline 6 starters in 67-72 are the same as the V8's
67 C20/ 68 C10 stepside/inline 250--current project 71 GMC 4x4 70 Blazer project-Zombie assault vehicle 67 4x4 Burb |
01-06-2021, 01:40 PM | #25 | |
Re: mini starters
I've got a 71 c10 with a 350/350 and what I believe to be the 168 tooth flywheel. How does this 2003 3500 Silverado starter wire to the 71? I know power, obviously, but what's the arrangement for the purple and yellow wires? Pics for reference. |
Thread Tools | |
Display Modes | |
