Old 12-02-2011, 01:19 PM   #1
blkcorvair
blkcorvair's Avatar
Correct Size Battery for 69 c10
looking for the correct replacement battery for my 69 Chevy C10. It has a
24f in it now. Is that the correct size? I'd like to find one of those Delco Battery toppers that make it look period correct, but I cant seem to fine the 24f style, just the 24
blkcorvair is offline   Reply With Quote
Old 12-02-2011, 02:24 PM   #2
john
member #16
john's Avatar
Re: Correct Size Battery for 69 c10
If I remember right 24F is a ford battery. The posts are reversed from a grp 24 which is the proper size.
john is offline   Reply With Quote
Old 12-02-2011, 03:06 PM   #3
StingRay
StingRay's Avatar
Yup 24f is Ford with reversed posts. A standard 24 is top post which is correct for your truck. A 74 should be side post and could be used if you wanted to go that way. The universal fit combo terminal type batteries usually work good too and in that case I find the side post ends best to use. You get the tops left over if you want to boost somebody.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 12-02-2011, 04:52 PM   #4
72lb4x4
Why not go to your favorite parts store web site, enter your truck's info and select a battery.
I'll bet it will be close to correct in size, CCA, and terminal orientation.
My way is to decide how I want the terminals, measure the battery tray, and go get the biggest CCA battery with the right terminals arrangement that fits in the tray.
From what I've seen in used vehicles the usual approach is to find the smallest possible battery, with the terminals on the wrong sides, buy that, and hack the wiring to make it work...
72lb4x4 is offline   Reply With Quote
Old 12-03-2011, 06:01 PM   #5
blkcorvair
blkcorvair's Avatar
lol. So Our trucks should have a standard Group 24 with the terminals not reversed (Like the 24R Than?) I stock group 24 at my shop so thats easy, Plus I can get a delco Battery topper for that one to make it look correct
Old 12-03-2011, 07:02 PM   #6
Sicklajoie
The Niner
Sicklajoie's Avatar
I've got one of those battery toppers and am happy with it.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 12-03-2011, 11:55 PM   #7
kcfirstbuild
where did you get the topper at ?
kcfirstbuild is offline   Reply With Quote
Old 12-04-2011, 04:44 AM   #8
Sicklajoie
The Niner
Sicklajoie's Avatar
http://www.batterytoppers.com/products/
Old 12-05-2011, 01:01 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Just to toss some info on here, 1970 was the last year on the top post. Side post started in 71.
