Old 12-11-2011, 02:37 PM   #1
mjensen
Yes...it's an obsession!
mjensen's Avatar
Gearing options needed
So, I'm really trying to decide how I want to gear my beast. Currently, it has a 4 speed, NP205 (I think), 4:10 rear (not orig), 4:56 front (orig). I am planning on going with a 4" lift and 35's.
So, I'm going to stick with the 4:10 ratio but I'm not sure about the tranny. I've thought about swapping in a NV4500, or another option may just add a GV Overdrive unit. It seems like the GV option would be easier, and would probably be about the same costs but I wanted to see if you all had an opinion.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 12-11-2011, 02:54 PM   #2
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: Gearing options needed
4:56 with a NV4500 on 35-37’s is a great combination. GV has great products but they tend to work better on 2wd trucks more than 4wd. That is just me .02 cents.
GM quit building great trucks in 1972
GM quit building good trucks in 1987
GM quit building decent trucks in 2006
GM quit building trucks in 2007.
GM is the leader in powertrain technology, why are they putting great powertrains in terrible wrappers?
Current vehicle collection:
1968 GMC C1500, 396, TH400
1978 Chevrolet K10, 8.1L, NV4500, NP205
1989 Chevrolet Suburban, 5.7L, NV4500, NP241
2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed
2013 Chevrolet Tahoe Z71
DirtyLarry is offline   Reply With Quote
Old 12-11-2011, 02:56 PM   #3
mjensen
mjensen's Avatar
Well, after seeing what you've accomplished I would gladly take your two cents
Mike
Old 12-11-2011, 05:05 PM   #4
Mike C
Mike C's Avatar
I don't have any issues keeping up with traffic with 4.10 and 35's with my SM465. It runs about 2800-2900 at 70 mph, which is not too bad with a carburetor on a small block. Certainly not bad enough for a $3-$4 THOUSAND dollar investment unless you were planning a bunch of high speed cross country trips. Put it together and drive it before making that decision. Then see what adding 37" tires would do.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
72 240Z-2.9l L6, triple Del'Lortos, T5, 12mm R200 LSD
85 FJ1100 & 01 XR400
86 Kawasaki X2 & 89 SX650 w/PJS cylinder and dual carbs
02 GMC 2500HD 4x4 Duramax
Old 12-11-2011, 08:48 PM   #5
mjensen
mjensen's Avatar
Thanks Mike...I like your logic. I think I'll just find me a 4.10 front to match and get it back together as is.
Mike
Old 12-12-2011, 08:37 AM   #6
space wrangler
seems like adding the GV unit would make for a really steep rear drive shaft angle. does anyone know how much length it adds to the transfer case? the GV website doesn't appear to give the dimensions of the unit. ..just pictures.
space wrangler is offline   Reply With Quote
Old 12-12-2011, 11:38 PM   #7
Mr. 250r
Mr. 250r's Avatar
The actually installed over drive unit is from the web the dimensions are from their website hope it helps
1987 K30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 t-top play toy
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
1995 Geo Metro - 5spd play toy
2001 3500 6spd 5.9L - Tow truck - Sold
2003 1500 Silverado - DD
2004 3500 6spd 5.9L - Tow truck - DD
LS info
http://lsx4u.com/lsxinfo.html
http://www.pirate4x4.com/tech/billav...SPrimer/Part1/
http://www.pirate4x4.com/tech/billav...SPrimer/Part2/
Mr. 250r is offline   Reply With Quote
Old 12-13-2011, 02:09 PM   #8
Redcap
Redcap's Avatar
Its too bad they didn't make it replace the transfercase adapter.
Redcap is offline   Reply With Quote
Old 12-13-2011, 09:48 PM   #9
mjensen
mjensen's Avatar
I think I'm just going to run what I have for sure. I'm not quite ready to tackle much more than swapping the front end for now. I do want to get it on the road and "tinker" after that
Thanks all for the input! I really appreciate it.
Mike
Old 12-13-2011, 11:55 PM   #10
andrewmp6
Why the gear vendors are you trying to make it easier on gas on ?
andrewmp6 is offline   Reply With Quote
Old 12-14-2011, 08:56 PM   #11
Mr. 250r
Mr. 250r's Avatar
Why not some extreme low range like a StaK transfer case and a gear vendors underdrive? lol real rock crawling ratios and also good for no gas mileage =-p
LS info
Old 12-14-2011, 09:21 PM   #12
mjensen
mjensen's Avatar
I was really wanting to get an overdrive for the amount of freeway cruising I will be doing. I really don't want to go through all the trouble of doing the tranny swap right now. I think a GV unit is really out of the question for this build.
Mike
Old 12-15-2011, 02:27 PM   #13
kwmech
If you really want to help your SM465, jump over to the Advance Adapter website and take a look at their overdrive unit...Ranger. It bolts in front of your trans, it is 7.5'' long. It essentially gives you an 8 speed trans and with the t-case 16 speeds. If you are towing in any kind of mountainous situations 2nd and 3rd gear overdrive are awesome. With a 4'' lift it will also help your front driveline angle
Old 12-15-2011, 08:49 PM   #14
mjensen
mjensen's Avatar
I'm loving that for two reasons, 1 - it's cheaper than a GV unit, and 2 - ANOTHER STICK TO SHIFT!!!! . In all seriousness though does anybody know anybody who has installed and used one of these? That looks like a pretty cool option to me. I would think this would cause some clearance issues with the gear shifter/seat, and the 4WD levers. Any input on that?
Mike
Old 12-15-2011, 09:59 PM   #15
Mr. 250r
Mr. 250r's Avatar
http://www.fordification.com/tech/torque-splitter.htm not in a chevy but might help couldn't find much else
LS info
Old 12-15-2011, 10:22 PM   #16
mjensen
mjensen's Avatar
That helps. I kinda like the thought of 3 sticks pokin' through the floorboard. I just may have to do this. I'm really surprised/worried though that nobody else has done this as it's almost half as much as the GV unit.
Mike
Old 05-07-2012, 06:27 PM   #17
SunSoaked
Any forward progress on this? I'm going for it in the next couple weeks. Was curious on how you addressed the clearance issues with the sticks.
"I once saw a six foot chicken eating prairie dogs like they were worms, but this was while driving between Janos, Chihuahua, Mexico and Agua Prieta, Sonora, Mexico on Route 9, after having consumed my share of El Presidente whiskey "
SunSoaked is offline   Reply With Quote
Old 05-07-2012, 11:23 PM   #18
mjensen
mjensen's Avatar
I've ordered the splitter, but its still on backorder. I have decided that I'm going to do some kind of solenoid to shift the beast just like the big rigs
Mike
Old 05-08-2012, 07:59 AM   #19
76k10
Active Member
I run 35s with 3.31 gears. With a TH350 it feels like I have an overdrive on the highway, but low range is mandatory on the trail and it gives me all the gearing I need.
76k10 is offline   Reply With Quote
Old 05-08-2012, 10:10 AM   #20
SunSoaked
Great idea. I like the look of the stick(s) poking up thru the floor like a bamboo forest..
However- I could mount a stick any size/shape/location I wanted to avoid the seat interference issue and just slave it to a switch/solenoid.
Forward thinking...
Old 05-08-2012, 09:08 PM   #21
mjensen
mjensen's Avatar
I'm not 100% sure until I get it, but I'm thinking I may be able to rework the shifter enough to clear the seat. I may be dead wrong on that, but who knows until I get the cab back on...or at least I don't want to think about it until then :LOL:
On another note, I got my tracking number today so IT'S ON IT'S WAY!!!
Mike
Old 05-08-2012, 09:09 PM   #22
rogerapage
I ordered a Ranger overdrive last week for a 4wheel drive with a Sm 465 and 205 . My measurements for the transfer case shifter may hit the edge of a bench seat. I plan to install buckets. The people at Advance seem like good people. This truck is a class project so it may be a few months before it is together.
rogerapage is offline   Reply With Quote
Old 05-08-2012, 09:16 PM   #23
mjensen
mjensen's Avatar
Darn...I was hoping you were going to say it's already installed so I could steal measurements and such
Mike
Old 05-09-2012, 08:34 PM   #24
rogerapage
The class has been working on the frame, drive train, brakes, as soon as I recieve the overdrive and install it I want to install the cab. Let me know if what I have would help.
Old 05-09-2012, 09:07 PM   #25
86c20
86c20's Avatar
what about a hole aux trans? one like a spicer?? i think it is a 3051A i may be wrong on the name but it was used in mid rang trucks. gives you a 2;1 under drive 1;1 and a .78 over same as the gear vendors and the ranger spliter. 2 wheel drive use only tho un less you fit a divored tcase in there. seen some of the diesel guys do it and they love it. turn a 4 speed into a 12 speed. and yes it will handle all of the power a gasser can make. think they are rated for 1000 lbs tq. there are bigger ones for more power. would work great in a 4 door long bed more then enough room but has been done on a long bed reg cab. later, mike
86c20 is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
