#26 | |
Re: Welding Patch Panels
[*]1951 Chevrolet 3100 |
#27 |
Active Member
![]() Join Date: Jul 2009
Do you guys paint the backside of your patches to keep rust from starting, particularly if you won't be able to reach them from behind after they are installed? What do you use that doesn't burn when you weld the patch in?
Rick 78 GMC SWB 4wd Project Fish Tremble 59 Chevy SWB Stepside (long term project) |
#28 |
you can use a weld thru primer but some of it is going to burn off there is not much you can do. I have used this http://www.eastwood.com/internal-fra...ay-nozzle.html in a few places that I could not get in to paint
55 2nd series Chevy Pickup 1987 Chevy Suburban (parting out) 2004 Chevy Aveo (Daily driver) 2011 Chevy Malibu (Wife's car) MSRA Member I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose. -George Carlin |
#29 |
Buy a name brand 220V mig and you will never regret it.
#30 |
this is what i started with, my first body panel attempt, take your time. i just finished the outer skin today, looks good for a novice.
http://67-72chevytrucks.com/vboard/s...d.php?t=530662 |
#31 | |
Active Member
#32 |
Not trying to hijack but my '55.2 has some rust-through along the gutters from failed sealant. Fortunately, no rust through on the cab "eyebrow" that I've found yet.
I've scraped away all the old sealant using a heat gun, wire wheeled it to shiny metal, but I know if I am seeing 1/8" rust-through "slots", its probably more severe than that. I don't have the skills to pull the entire roof off but I don't want to do a schitty coverup either. I was thinking of grinding the rust-through areas back to solid metal as best I can judge it without SEEING the back side. Then make small sheet metal strips for the areas to be repaired, weld them in, grind smooth, and prime. THEN, use the Eastwood frame protection stuff cited in post #28 above ALL around the inside of the roof using the limited access that a removed headliner give you. Does this sound too Mickey Mouse? How have you (Bam, etc) dealt with this? |
#33 | |
#34 | |
But maybe I misunderstand what I'm going to find. Where I'm talking about is RIGHT where the curve of the roof meets the gutter on the outside of the truck - THAT'S where its rusted through. I have been assuming when I grind there I'll be grinding into the area behind where your "After" photo shows. The dead space between the inner roof line and the actual exterior roof metal. Does that make sense at all? I've also thought about investing in one of THESE to get a look at what's happening in there: http://www.harborfreight.com/digital...era-67979.html What do you think, have I got it all wrong? |
#35 | ||
#36 |
Thanks so much for posting that. I think where mine is rusted through is right where that horizontal line is in your photo above the jagged metal.
Would you advise one or two cans of that Eastwood stuff to be enough for all around the perimeter of the cab roof line? Last, an old friend filled the seams inside the cab where the A and B pillars meet the roof/ceiling material. It looked so much better and more finished but I always thought relying on Bondo not to crack there long term was a bad idea. I plan on filling mine with mig and grinding smooth. Any reason you can think of NOT to do this? Sorry for so many questions. |
#37 |
with the Eastwood stuff I was able to do around the whole cab and down the cowl with about a can and a half. it take a little bit to get use to spraying it. I bought 2 cans when it was on sale i figured if i had 2 i would not have to buy another can an pay for shipping again.
For the seams in the cab a know that i have seen some say that they help when the frame flexes so if you weld them up then you need to box the frame to stop the flex in there. I can see that but I'm not an engineer so I don't know for sure. But If you just fill it with bondo it will crack and look terrible down the road.
#38 |
So will you be welding your seams, or not?
The way I figure it is they're ALREADY welded (though probably spot welded) so they're already pretty inflexible. I will weld mine, but my truck will be a weekend driver. I want to, so I'm going to. Anyone else have experience on welding up those seams? |
#39 |
I'm not welding them.
#40 |
Gentlemen,
Thanks for all the great information on this thread...I finally drop some coin on 220v Hobart welder(Model 187). After much searching and researching I decided this machine is going to help me build my baby.... Thanks again for all the great input and comments. ![]() PS Glad I didnt settle for 120 |
#41 |
in a pinch a 110v welder will weld 3/16" if you preheat with some mapp gas and go REAL slow!
pic's http://community.webshots.com/user/55dude |
#42 | |
Have a good one
#43 |
Certified Car Nut
![]() Join Date: Jan 2005
You've don the right thing buddy. I have the same Hobart and its a very nice machine. Happy welding buddy.
BAM Kabwe aka Bam's 55/58 Chevy Truck Project Fixing a mess of a clip installation If doing it my way is wrong, I don't want to be right. |
#44 | |
Thanks for the reassurance that I made a good choice. I originally was gonna go Blue but man they just cost too much or are junk with in my price range. For my needs this machine is perfect, prolly more power than I'll ever need. My thinking is better to have something that can do some patch work with or build a frame up if need be....Have a great one Kabwe
#45 |
i think Hobart is now owened by miller. anyway that is what a miller rep told me.
my 72 cummins build. http://67-72chevytrucks.com/vboard/s...=1#post5204353 My GMC build. http://67-72chevytrucks.com/vboard/s...d.php?t=536602 |
#46 | |
That was definetley a factor in choosing Hobart. From what ive read Hobarts are built by big blue aka miller but certain parts on units are not the same as a reg miller..... Posted via Mobile Device |
#47 |
Certified Car Nut
Well if its any consolation to you I had my Hobart for around 7 years and I have never had an issue with it and I use mine as a work horse. Now I have a miller tig but my Hobart is still my work horse, so if you don't like it you can drop it by my house I always like new shiny tools.lol
#48 |
I got a Clarke 180 for Christmas last year. I am on my second spool of wire and it does a great job. I think it is the same as the Eastwood from what I've read. I had no prior welding experience and just welded a camaro subframe to the front of my truck a couple months back. Don't be afraid it's just metal. Worst case you have to cut it and reweld it. Easy Peasy. lol
2006 Chevy Silverado 3500(Duaramax/Allison) - DD 1997 Honda Civic - Work Beater 1981 Chevy Malibu - Race Car 1959 Chevy Truck - Project http://67-72chevytrucks.com/vboard/s...d.php?t=481442 2006 Honda Accord - Wife's ride |
#49 | |
Ha Ha Ha.....Sure I'll drop off Hobart at your place and a case of Beer.....In Exchange for your 55' truckl ![]() Take it easy |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
