Old 05-19-2012, 10:23 AM   #1
74 shortbed 406
building moderate trail rig
I just recently picked up a 78 k25 cheap. The body is rough and I have a pic posted of it on here. Bed is junk and will be building some sort of flatbed for it. It has a dead stock drivetrain which includes 350 with q-jet, 400, 203, d44 front and a 14 bolt ff(thought it was sf for some reason). I am not a dedicated rock crawled and the places I will be at 90% of the time are the woods. I still would like this truck to be functional as a much of a daily driver as can be. I am thinking of trimming the frame in the rear as short as I can, build bed accordingly, do a shackle flip in rear and maybe springs to get desired lift. I am debating on tire size, 35 is what's in my head. Motor is going to get some help in the way of built into 355 or 383. Haven't decided what tranny, keep the 400 or swap to 465. Haven't decided on the tcase. This will be the first I have owned with the 203. So any links or pics that are related would be awesome. This is also the first time I have had a 3/4 ton, I am looking to lock rear, maybe air lock front?
1978 GMC K25
2002 Dodge Dakota R/T rc swb
In need of some more goodies.
74 shortbed 406 is offline   Reply With Quote
Old 05-19-2012, 06:01 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: building moderate trail rig
Sounds like a good list of to do to me! I am a fan of auto trans. so i'd keep the 400, plus thats a few less things to have to mess with. How much lift to you want. You will only need 4-6 for 35s.
1971 Cheyenne 1 Ton 4x4, BFM486/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 05-19-2012, 07:22 PM   #3
74 shortbed 406
I haven't decided on the flip which should give around5-6 or going 4 link and springs and going up 6
1978 GMC K25
Old 05-20-2012, 06:39 AM   #4
Senior Moment
4-link...moderate trail rig? You're getting into fabrication type modification and that's the road to an all-out trail rig. Keep it simple,like you started off describing and you'll be fine. Actually,a stock truck with the right tires is a great moderate trail rig. Locked differentials are the one best thing you can do and should be one of the first things to do. The TH400/NP203 will do fine
Here's my list posted in order of priority:
* Front springs/shackle flip rear...maybe consider going to 52" front springs
*Tires...whatever fits with whatever lift you do. Maybe do some trimming
*Lockers
*Winch...because the farther in you can go,the harder to get out
*Motor
*Skid plates/rub protection,beef up parts like u-joints or whatever else already broke,roll protection,heavier cooling,compressor,sponsors
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed"......GMC
`72 Sierra Custom Camper K2500 Wideside: 350/TH350/4.10 PowerLoc/AC/Tilt/Tach
`67 Super Custom 1500 SWB Wideside: 327/M22/3.42 posi...project "Poor Boy" (using what I have)
'71 Custom 30 DRW Wrecker: 350/4spd/5.14
'85 Sierra Jimmy K2500: 6.2/700r4/4.10 Locker
'92 SLE K3500 SRW: 6.5TD/NV4500/4.10 Locker
R.I.P. East Side Low Life ____________ R.I.P. El Jay__
special-K is online now   Reply With Quote
Old 05-20-2012, 06:48 AM   #5
jjzepplin
jjzepplin's Avatar
Yep that thing sounds pretty stout the way it is. I'd replace broken or worn pieces and give it a try. Might be all you need stock.
I wish I found this site when I was 19 and bought my first 72.
It's just another big pretty scar.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda
72 Blazer 2wd conversion project "No Daggum Money"
jjzepplin is offline   Reply With Quote
Old 05-20-2012, 07:08 AM   #6
74 shortbed 406
I know four link would be overkill, but I can increase departure angle by a large margin. I am not do worried about fabrication, I have 10yrs experience in that and my uncle builds racecars and knows the calculations for setting them up. I went and talked to my buddy last night about the truck, and he is giving me 3 sets of tires with it, not new sets but decent rubber. I should be able to do some swapping around and have no money in truck. I know I said no rock crawling but the banks on the dried creeks I would be playing in are steep, not real tall, just steep so approach and departure angles need to be decent.
1978 GMC K25
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
