Old 07-13-2012, 04:38 PM   #1
68 TT
Still plays with trucks
68 TT's Avatar
Hooker 68-72 big block Chevelle headers fit my 69 C10
I just put a set of 2" tube Hooker 2455HKR Competition series big block Chevelle headers I had sitting around on my 69 stepside.
They fit great but will require a modified transmission crossmember for exhaust routing since they are tucked up about 3" higher than truck headers. Great added ground clearance for lowered trucks.
The driver side clam shell motor mount housing (if you are running that style) will need a small notch to let them bolt up.
I was surprised they fit at all let alone so well since I had earlier tried a set of Camaro headers that didn't even come close to fitting.
In the pics the passenger side collector will come up a bit as it is hitting the T-350 crossmember flange and the driver side will come down a bit with the required mods to the clam shell.
I didn't make the modifications to mine to make them bolt up as the engine is coming out but they would work great with good floor pan, frame and suspension clearance all around.
As long as you have an auto trans or a hydraulic clutch no other mods would be needed to use them. The rear tube is right in the middle of where the clutch Z-bar would go. There is plenty of room to re-route that tube to make it work if you so desire.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 07-14-2012, 12:51 AM   #2
Captainfab
60-66 Nut
Re: Hooker 68-72 big block Chevelle headers fit my 69 C10
Thanks for posting this info along with pics. It is always good to have fitment info on non standard truck parts. I have heard long ago that Chevelle big block headers will work on the trucks, but I have never had a chance to try the fitment.
Those issues are relatively minor things to deal with to be able to have much better ground clearance.
Old 07-18-2012, 03:44 AM   #3
68 TT
68 TT's Avatar
Originally Posted by Captainfab View Post
...Those issues are relatively minor things to deal with to be able to have much better ground clearance.
I hope the info can help someone else out.
You could always build a custom crossmember to work with them in your spare time.
Still working 6+ days a week John?
Old 07-18-2012, 10:45 AM   #4
cdowns
cdowns's Avatar
i'm lookin at a set brand new that is on the daytona craigs
Old 07-18-2012, 11:38 PM   #5
Captainfab
60-66 Nut
Yeah, 70-80 hrs @ 7 days a week.
Are you still staying busy?
Old 07-19-2012, 06:04 AM   #6
68 TT
68 TT's Avatar
Yikes. 10-12 hours a day every day gets old quick. I don't miss working that many hours at all. You need some more help so you can get a break and have some time for yourself.
I have way too many projects to do as usual. Trying to stay on task and get something done this summer.
Old 07-19-2012, 11:21 PM   #7
J kippin
J kippin's Avatar
just a quick thought.. you are using 73 up frame mounts does this change the engine height in the chassis and what if you are useing raised port heads? I wonder how much this will effect the trans cross member.
J kippin is offline   Reply With Quote
Old 07-20-2012, 02:31 AM   #8
68 TT
68 TT's Avatar
I don't think they move the engine up at all. If they do it is not much.
If I had the engine in there still I could have swapped out the mounts to see. Any change of height wouldn't alter where the collectors exit though.
Raised port heads would help clearance at the motor mount stand.
Old 10-26-2012, 03:12 PM   #9
BossHogg69
motor exploder
BossHogg69's Avatar
Just wanted to add some more info to this thread... I tried a set of Hedman Elite headers for 68-72 Chevelles (#68198) on my '69 stepside as well. They pretty much fit just like 68 TT's hooker headers did, but mine are 1.75" tubes. I'm using the '72 BB motor mounts and also had contact on the clamshell bracket. I already had purchased a set of Hedman Elite headers for 67-up trucks (#69820), but the hung down WAY low. Below is a pic of the truck headers on the drivers side and the chevelle headers on the pass side. BIG difference in ground clearance, since my truck is lowered. The truck headers hung down even with the bottom of the lower a-arm... The chevelle headers are dead even with the bottom of the frame rail.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 10-29-2012, 03:20 AM   #10
68 TT
68 TT's Avatar
Nice pic to add to the thread. Great side by side view for comparison.
Old 07-16-2013, 09:05 PM   #11
nw68
does anyone know of headers that tuck up next to the frame rails?
nw68 is offline   Reply With Quote
Old 09-04-2014, 03:10 PM   #12
hdff
hdff's Avatar
i know this thread is a couple of years old but i have a question. i assume the frames are the same on a 69 and 71 so i assume these headers would fit a 71 with a 402 nicely also?
hdff is offline   Reply With Quote
Old 09-04-2014, 11:57 PM   #13
Captainfab
60-66 Nut
Yes your '72 frame is the same as a '69. In fact the frames from '63-'72 are basically the same. However the '68-'72's have been clearanced for the big block exhaust manifolds.
Old 09-16-2014, 12:22 PM   #14
True 67
Great information guys..
True
True 67 is offline   Reply With Quote
Old 06-10-2015, 08:40 AM   #15
68 TT
68 TT's Avatar
When I put them into my 67 C10 I had to trim about a 1/4" or so off of the width of the top of the frame rail for clearance. I figured since the factory did this to the later ones that it wouldn't be a bad thing to do. Plenty of meat left on the top flange to keep things strong.
Old 08-09-2015, 11:47 AM   #16
Swiftshifter68
Swiftshifter68's Avatar
Great thread with good pic's!
I'm literally doing this same header-switch on a customer's 496cid GMC, so the larger 2" primary size is what I was after (Brodix topend + mild Comp roller valvetrain). From '67-72 2" "truck" headers to these 2" "Chevelle" headers is a savings of ~$200, the added ground clearance is a bonus. Much-appreciated on the insight! Thank you!
Swiftshifter68 is offline   Reply With Quote
Old 08-09-2015, 12:31 PM   #17
vidman
vidman's Avatar
Some pics of the same headers on my Brodix 504. Great fit
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 08-10-2015, 11:38 AM   #18
BossHogg69
motor exploder
BossHogg69's Avatar
Vidman - my exhaust system looks almost exactly like yours - H pipe, black ceramic and all... Same Chevelle headers from post #9 above.
Adam
Old 09-02-2015, 08:16 PM   #19
scoots71
Are you guys using the stock auto shift linkage
scoots71 is offline   Reply With Quote
Old 09-03-2015, 01:53 AM   #20
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Welcome to the forum Scoots! Thats a VERY good question because I have a (brand new) set of those Chevelle/El Camino BBC headers hanging on the wall because they would not clear the column shift TB350 linkage! Taking them to a swap meet "Greaserama" in Kansas City, this weekend...PS. $200 plus shipping, they have 45 degree vacuum/O2 sensor bungs welded to the collectors and 2 coats of VHT Flame Proof Ceramic paint in Aluminum if someone here wants them...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 09-03-2015, 09:20 AM   #21
scoots71
Originally Posted by Ironangel View Post
Welcome to the forum Scoots! Thats a VERY good question because I have a (brand new) set of those Chevelle/El Camino BBC headers hanging on the wall because they would not clear the column shift TB350/400 linkage! Taking them to a swap meet "Greaserama" in Kansas City, this weekend...PS. $200 plus shipping, they have 45 degree vacuum/O2 sensor bungs welded to the collectors and 2 coats of VHT Flame Proof Ceramic paint in Aluminum if someone here wants them...
Old 09-03-2015, 09:21 AM   #22
scoots71
Thank you for the heads up where was the issue with the linkage
Old 09-03-2015, 10:11 AM   #23
Ironangel
Ironangel's Avatar
Being narrower and higher, they tucked up right underneath the horizontal pin/shaft that bolts to the frame. That shaft is what holds the part that connects the arm from the column to the part that bolts to the transmission shifter shaft. It wouldn't let the shifter rotate through the gear pattern. This may or may not be a problem with the floor shifter used in Chevelles and Caminos...? I was in a hurry to make a local car show and needed headers fast so I opted for a set of Hedman 69110's...They're long tube and hang down, but not as far as the Hookers and the Hedmans line right up with the openings in the cross member. If you have Amazon "Prime" then you can have them on your door step in 48 hours..."Win,win!" Amazon.com: Hedman 69110 Chevy Pu 2 & 4Wd Big... Amazon.com: Hedman 69110 Chevy Pu 2 & 4Wd Big...
"Two Seventy Two's"
02 3/4 ton Express
Old 09-03-2015, 10:25 AM   #24
scoots71
Old 09-03-2015, 10:25 AM   #25
scoots71
How low would you say they hang I'm going with a 4-6 drop hotchkis kit
