Old 07-23-2012, 07:26 PM   #1
INSIDIOUS '86
INSIDIOUS '86's Avatar
94 3500 4x4 gmc. Transfer case wont work?
So my old mans 94 gmc dually extended cab 3500 runs fine and is great all around. It usaully sits for months at time before being driven. No matter what we do it wont go into low or high gear for 4wd. Basicly its not doung anything. Any of you guys have this issue? Not sure if its vacuum controled or electric sylinoid or mechanical? Thanks for any help guys!
377 sbc thumpr cam th350 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers...almost to quiet
One of the proud few to have HID projectors
custom door locks and valve cover studs coming real soon!!l
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is online now   Reply With Quote
Old 07-27-2012, 07:27 PM   #2
64swb
64swb's Avatar
Re: 94 3500 4x4 gmc. Transfer case wont work?
Does the transfer case actually shift into 4hi/lo? I'm assuming the tcase actually shifts into either one of these ranges but the front doesn't engage. If this is the case its most likely the front differential actuator. It is electronic and they are notorious for failing. You can get a replacement stock type one, or like I did there is and aftermarket cable setup you can convert to so you have a pull cable under the dash to lock the front end in. I believe it is made by posi lock? Can't remember, I got mine through summit though.
1965 Impala SS, 1978 Chevy C10, 1968 Olds Cutlass, 1986 Chevy K20 'Burb, 1970 Chevelle, 1997 GMC Yukon, 1996 K2500 'Burb 1977 Chevy K10, 1970 Ford F-250, 1964 Chevy K10, '57 Chevy 6500 wrecker, 1950 GMC 2 ton, 1972 Ford F-350 Dump, 1964 El Camino, 2002 Corvette
64swb is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
