Active Member
![]() Join Date: Aug 2011
1/2 ton to 3/4 ton swap help needed
I have axles out of a 1972 3/4 ton 4x4, the rear is an Eaton and the front a Dana 44. Can I swap these into a 1972 1/2 ton 4x4 but just unbolting and bolting on?
#2 | |
Re: 1/2 ton to 3/4 ton swap help needed
87 Suburban R20 (6bt Cummins) 79 Cherokee Chief (454 from Suburban) - both in progress http://lobie4x4.com |
Happy New Year
![]() ![]() Join Date: Mar 2000
RPIcka I moved your post to the 4x4 forum. Your going to get better action over here.
Should bolt in no problem, the u joint is a 1350 on the eaton so if you are using the 1/2 ton drive line you need one of those conversion joints, 1310 on one end 1350 on the other. The front will bolt right in.
1969 4x4 Nothing beats a good rock drill and some dynamite |
Active Member
So what exactly seperates the 1/2 tons and 3/4 tons? Is it just the axles or what else?
Heavier springs on the 3/4
Current: 1971 K10 lwb Past: 1972 c10 lwb 1969 c10 swb 1977 c10 lwb more old jeeps than I want to remember! |
Heavier frame, bigger brakes and axles, different shocks, wheels and tires, etc.
44 Willys MB 52 M38A1 64 Corvette Coupe 68 Camaro 'vert LT1 & TH700 69 Z/28 355 12.6's @110 72 Jimmy 4WD 4spd 4" & 35's 72 240Z-2.9l L6, triple Del'Lortos, T5, 12mm R200 LSD 85 FJ1100 & 01 XR400 86 Kawasaki X2 & 89 SX650 w/PJS cylinder and dual carbs 02 GMC 2500HD 4x4 Duramax |
it's all about the +42 inches
![]() Join Date: Jan 2007
I directly swapped an H052 for the 12 bolt in my K5 by using a 1310-1350 universal joint. With a 4" lift the drive shaft length was fine and didn't need to be changed. Without a lift, I have no idea if the drive shaft length will be o.k. or too long....
1972 C10 5.3L/4L60E 12bolt 5Lug 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! |
Active Member
I just swapped from a 12 bolt dana 44 1/2 ton combo to a 14 bolt 44 3/4 ton combo. I kept the 1/2 ton springs only because I wasnt comfortable relocating the spring mounts on the frame, but I did add overloads. Both the 14 bolt and the eaton are full floaters I believe, which are stronger than the 12 bolt. I upgraded because I haul a lot of firewood, and last summer I had 2 cords on and bent the 12 bolt. I wanted heavy duty, but I had to upgrade what I had. Seems to be working so far.
If you want a short bed truck they was 1/2 ton only,But if you want a truck to use as a truck i would get a 3/4 ton or maybe a 1ton depends how it will be used.The eaton was a full floater the 14 bolt they made in full floater and a semi floater but i think the semi floater was in the 88 up body style.
gets board easy.......
Actually, I remember reading the 1/2 and 3/4 frames are the same, just brakes and springs upgraded.
The 3/4 ton may have had bolt in frame braces, but the only larger, stronger frames are on true 1 tons Posted via Mobile Device |
#13 |
Senior Moment
![]() Join Date: Nov 2004
1/2t and 3/4t frames are the same. The difference is in the axles,suspension,brakes,wheels,and tires.
The best way to covert to 3/4t is use a 3/4t rear driveshaft and shorten it. If you are not lifting you will need driveshaft work anyway due to the larger differential.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed"......GMC`72 Sierra Custom Camper K2500 Wideside: 350/TH350/4.10 PowerLoc/AC/Tilt/Tach `67 Super Custom 1500 SWB Wideside: 327/M22/3.42 posi...project "Poor Boy" (using what I have) '71 Custom 30 DRW Wrecker: 350/4spd/5.14 '85 Sierra Jimmy K2500: 6.2/700r4/4.10 Locker '92 SLE K3500 SRW: 6.5TD/NV4500/4.10 Locker Tim R.I.P. East Side Low Life ____________ R.I.P. El Jay__ |
#14 |
Active Member
Thanks guys!
| Bookmarks |
| Thread Tools | |
| Display Modes | |
