Old 11-24-2012, 06:20 PM   #1
chris989
powers steering pressure/return
Hello,
I found one post on the site stating the pressure hose from the pump goes to the port closet to the frame and the return is closer to the tire.
Can anyone confirm this? I have an 89 suburban 4wd. I just put a new gear box on and swore I had the lines correct, I had power steering and it was quiet, but after a very short road test it blew the seal out of my steering pump. Not just a drip, but pouring out.
The new box felt more stiff/heavy than the old box. Just thought it was because it was new. Could the new box not be allowing pressure bypass???
Thank you,
Chris
chris989 is offline   Reply With Quote
Old 11-25-2012, 11:52 AM   #2
chris989
Re: powers steering pressure/return
Found my answer, I feel a little foolish. Although both line use a 18 mm wrench the threads are smaller on the return. It can not be installed backwards.
Old 11-25-2012, 01:46 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
Highest line up is always return
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
gearbox, hose, steering
