12-31-2012, 04:25 AM | #1 |
Starting and running engine on stand
Getting ready to build a motor break in/set up stand. Anyone have any suggestions?
And what type of torsional twist does a motor have when rev’d up? As in how big, and or side support does the stand need so the motor doesn’t “fall over”. Deciding on mostly 2x2 steel frame, tachometer/temp/oil gauges and small gallon or so fuel canister. Radiator with an electric fan. Anyone built one before? Any pictures? |
12-31-2012, 10:45 AM | #2 |
Re: Starting and running engine on stand
I have used a old tire on the gound. But I did not rev it up.That would be the redneck in me
12-31-2012, 11:02 AM | #3 |
12-31-2012, 11:13 AM | #4 |
Active Member
Well, I was going to say I have run my engines on a rebuild stand and regular engine stand with no problems but if you have spent 7K on yours try to find something a little mores substantial. Why take a chance...
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
12-31-2012, 11:14 AM | #5 |
Here's a link to some ideas.
http://www.jalopyjournal.com/forum/s...d.php?t=409066 |
12-31-2012, 01:14 PM | #6 |
I've used a modified irrigation engine stand. I'll post pictures. There isn't much twist on the stand since the flywheel isn't hooked to anything. 2x2 square tubing is strong enough. Put some big casters under it so you can roll it out of the way when you're not using it. I like to have a tach, oil, and water temp gauges.
01-01-2013, 12:11 AM | #7 |
60-66 Nut
I have one that I built 25+ years ago. I can get you some pics tomorrow if you like.
01-01-2013, 12:44 AM | #8 |
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
01-01-2013, 03:23 AM | #9 |
Ran mine on an ac Delco engine stand twice just don't try to rev the crud out of it you'll be fine. If you want some insurance build two arms that bolt to te block at mounts and go to the ground. Then hang a radiator on it somewhere or just run a hose into the water pump holes..
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
01-01-2013, 09:43 AM | #10 |
I broke in my 454 on a Summit engine cradle. I revved it a couple times and didn't move. Only $30 IIRC...
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
01-01-2013, 11:44 AM | #11 |
My Carbon Footprint
You can make is as simple or complex as you want. I took the better engine stand that is a C shape on the bottom rather than a T. I built two struts that came off the legs up to the engine mounts. Since there will be nothing bolted to the crank besides flywheel or flexplate, you will be surprised by how little it will move. I used a bar stool to hold up the radiator and the hoses actually held it in place really well.
http://s120.photobucket.com/albums/o...ent=460BBC.mp4 |
01-01-2013, 11:46 PM | #12 |
60-66 Nut
Here are some pics of mine.
If I were to build another one, I would set it up to use a bellhousing instead of an engine stand head
01-02-2013, 12:40 AM | #13 |
My Carbon Footprint
Nice Captain.....even using the ole Les Schwab battery! I must say though....interesting to have the panel right in front of the headers instead of off to the side. Is that why you have burnt kneecaps??
PS...man you got some stuff! |
01-02-2013, 04:51 AM | #14 |
Thanks for the replies. I think I might be using a rolling display chassis I have for air-ride as my test stand/break in stand. My real estate is valuable and another 'thing' to take up room in the shop might be a no-go.
A motor sitting in a chassis is always an eye catcher.. |
01-03-2013, 12:44 AM | #15 |
60-66 Nut
Thanks for the compliment. It isn't real nice, but it does do the job.
yeah, I gots a bunch o' stuff
07-19-2016, 12:03 PM | #16 |
an old but good thread to bring back from the dead..
tubbed 1984 gmc jmmy http://67-72chevytrucks.com/vboard/s...d.php?t=639738 Alice Hombre http://67-72chevytrucks.com/vboard/s...d.php?t=808454 |
