Old 02-21-2013, 04:27 PM   #1
Taylor21293
Taylor21293's Avatar
Rear Axle Swap Questions!
So I have a 1972 Chevy C10 LWB, and I'm switching out the rear end in her. I found a 12 bolt rear end out of a 1972 K5 Blazer, and wanted to know if that rear end will fit my C10?
Eatin' up Dodges and ****tin' out Fords
Taylor21293 is offline   Reply With Quote
Old 02-21-2013, 04:39 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Rear Axle Swap Questions!
Does your truck have leaf springs or coils? The K5's should be a leaf spring set up. If your C10 has coils in the rear, you will need to change some bracketry which requires welding.
I am not sure about the width and the yoke. Also, what year is your C10 and does it have 5 or 6 lugs. The K5 will have 6.
TBONE1964 is offline   Reply With Quote
Old 02-21-2013, 04:53 PM   #3
Taylor21293
My truck has leaves.
Old 02-22-2013, 08:52 PM   #4
Mike C
Mike C's Avatar
2 wheel drive trucks use 42.5" spring centers and 4x4 uses 40.5". Four wheel drives and Longhorns use 2.5" wide springs and two wheel drive has 2.25" spring. 2 wheel drive is 5 lug and 4x4 is 6 lug, at least in the scenario of your truck and the Blazer. Long story short....No.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-22-2013, 08:57 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Good info!^^^
Keith
Convert to disc brakes.
Old 02-22-2013, 09:37 PM   #6
buckskins4ever
buckskins4ever's Avatar
No wont fit...without welding over brackets..... Taylor......whats in it right now, what are you wanting it to do?
buckskins4ever is offline   Reply With Quote
Old 02-23-2013, 10:11 AM   #7
Mike C
Mike C's Avatar
And my assumption is the Blazer is a 4x4 and NOT a 2x4 in which case the perches are in the wrong spot but the 5 lug will be same.
44 Willys MB
52 M38A1
64 Corvette Coupe
