09-12-2013, 10:00 PM | #1 |
Inlinetube my only option for 4x4 brake lines?
Basically what the title said. Are all of you guys going to inlinetube for 4x4 brake line kits?
09-12-2013, 10:38 PM | #2 |
What?
Re: Inlinetube my only option for 4x4 brake lines?
I did my own.
But, I did go to Inline tube for my rear e brake cables. They do good work, but their shipping costs and policies are not something to be desired.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
09-13-2013, 02:35 AM | #3 |
I think its them or bend your own lines.
09-13-2013, 12:14 PM | #4 |
I just Googled "Pre bent brake line tubes" and got this.
http://www.classictube.com/resources...m-classic-tube
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
09-13-2013, 10:53 PM | #5 |
Not worth the price. Get lines at your local parts store and a $5 bender from harbor freight and bend your own.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
09-14-2013, 11:20 AM | #6 |
I have inline tubes stainless kit on my K5 and its a nice kit. Just installed their disc/disc prop valve but haven't driven the truck yet.
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
09-15-2013, 12:17 AM | #7 |
I think thats what I'm gonna end up doing
09-15-2013, 01:32 PM | #8 |
Bent my own here. Got the Eastwood bender and their 25' coil of brake line. Worked pretty good.
09-15-2013, 03:04 PM | #9 |
Nice work mjensen
09-15-2013, 04:28 PM | #10 |
Beat me to it Jason! Very nice work indeed. I got my front 4x4 e brake cable from Napa but I think that they outsourced it from Inline. While the quality is good, it wasn't 180 bucks good. I would bend my own lines. As seen here, you can do your own high quality lines on the cheap!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
09-15-2013, 04:28 PM | #11 |
That is a very nice/clean job.
I think it boils down to the flaring part. Personally, I hate flaring lines so I went with the kit, however, if you are good at it, you can save yourself alot of money.
09-15-2013, 07:11 PM | #12 |
Thanks all. A quality flaring tool is definitely worth the money. I just used a cheapy one from O'Reilly Auto. If you make sure to lube the end first it first, it will do the job.
09-15-2013, 10:59 PM | #13 | |
http://www.sears.com/craftsman-45-de...5000P?prdNo=19
09-15-2013, 11:07 PM | #14 |
Nope...for stock applications that is the one you want. Make sure to practice on some scrap, make sure to chamfer the end, then hit it with some sort of lube. I can't remember what I used on mine, but it was a thicker consistency than WD.
09-15-2013, 11:22 PM | #15 |
Thanks for the tips!
09-16-2013, 09:00 PM | #16 |
Wow very nice job mjensen!
09-16-2013, 10:34 PM | #17 |
Thanks! I really appreciate the compliments. Now, if I can do it...anybody can
09-17-2013, 10:36 AM | #18 |
I used the craftsman flaring tool as well. I keep it lubed with grease and so far so good after doing stainless lines on two trucks. You can get a couple size benders from someplace like harbor freight. But they dont do as well on larger diameter stainless lines, like my 3/8" fuel line, because the stainless steel is much harder. Mild steel lines should be much easier.
09-18-2013, 03:22 PM | #19 |
NAPA also has pre flared brake lines with fittings starting at about 1' and going to 6' or so. I got an old school flaring tool at a retired machinists yard sale and went to town. Russell sells braided stainless for the hardline to caliper and rear tee connection. Look in the early part of my build thread for details. I used the same except 3/8 for gas line. I tossed my cheap bender after it messed up some bends and spent the money on a quality one that bends up to 3/8 with no kinks.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
