11-18-2013, 01:44 AM | #1 |
60-66 Nut
Rear Cab Mount Brackets
These are a pair of original rear cab mount brackets, that have been abrasive blasted. There is a little pitting from rust where the rubber mount goes, but they are very useable. I have reamed the rivet holes out to 7/16" and included new grade 8 hardware. I'm asking $55.00 shipped in the US.
11-18-2013, 01:53 AM | #2 |
But Found Her 25yrs Later!
Re: Rear Cab Mount Brackets
These also work as a good solution for the 3/4 rear cab mounts that often fail. I got mine from Tony, but these you have listed are a great deal less $.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
11-18-2013, 08:30 AM | #3 |
I may need these I'm about 10 hours from home working and can't check out my frame until Friday....changing the frame from my 60 to a 66 frame....will also need the power steering conversion and the brake booster bracket as well
11-27-2013, 02:31 AM | #4 |
60-66 Nut
Ttt
01-02-2014, 12:37 AM | #5 |
Still for sale?
66' custom camper 327/3spd 3.5/5 drop 17"s 2013 Subaru STI stage 1, exhaust, springs, sways ect 2002 mustang Gt. Paxton novi 2000, caged, tubular everything, 441/409 hp/tq too much to list. 1994 dodge cummins, straight piped, nv4500 swapped/built too much to list. |
01-02-2014, 12:42 AM | #6 |
60-66 Nut
Yes I still have them.
01-02-2014, 12:42 AM | #7 |
Oh and would i need your steering box adaptor to put a 72' manual box on my 66 that im swapping a 72 front end in?
01-02-2014, 01:29 AM | #8 |
Obviously don't want to spend extra on shipping if i don't need it. Do you have any solutions for track bars? I got a ho52 being replaced by a leaf spring 12 bolt so i need to get a track bar mount or a whole new set up.
01-02-2014, 01:47 AM | #9 | |
60-66 Nut
Yes you will need a steering box adapter plate, and possibly the tube and flange if you are keeping the original steeing column. Why not just go with a power steering box? I do not have anything for the panhard bar. You can simply cut the original off of the HO52 and weld it to the 12 bolt axle tube. I do have new trailing arm mounts though.
01-02-2014, 03:43 AM | #10 |
Dang was kinda assuming the manual box would bolt in cause its a manual box truck.
01-02-2014, 03:45 AM | #11 |
And i have a good manual box and i don't have any power steering items.
01-03-2014, 12:01 AM | #12 | |
60-66 Nut
If you just want manual steering why not keep your original steeing box?
If you did want power steering, a power steering box shouldn't be that hard to find over there. GM made millions of them from '68-'87. Quote:
01-03-2014, 01:36 AM | #13 |
Would it bolt to the 72 steering? I want the cab mounts what do we do for pay pal?
01-03-2014, 01:52 AM | #14 |
60-66 Nut
Yes your original pitman arm will bolt up to the '71-'87 draglinks.
I'll send you a PM with payment details.
01-03-2014, 01:58 AM | #15 |
I didnt think it would. Well thats cool. Thanks for the info and the cab mounts!
01-04-2014, 01:02 AM | #16 |
60-66 Nut
SOLD to natecr
Thanks Nate, they are on their way
01-08-2014, 01:15 AM | #17 |
Got them yesterday thanks again. Keeping an eye out for parts from you i can use! On a side note i have a c20 looking for pan hard bar bushings. All the poly one say only for c10 any ideas? Are the trailing arm bushings the same for c10 and c20?
01-08-2014, 02:35 AM | #18 |
60-66 Nut
Both the panhard bar and the trailing arm bushings are the same between the C10 and C20.
