Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Electrical
Closed Thread
Old 04-15-2012, 06:11 PM   #1
100mph
Push Button Start - in factory igntion
To read the original thread and discussion on this topic go here- LINK
If anyone is interested I found a great push button start system that fits in the factory ignition bezel.
Name:  finished install.jpg
and its a really simple install too.
Just remove the factory ignition from the dash and break off the connector
Name:  breaking connector off.jpg
Then you just need to file down a ridge inside the housing so the start button plug will fit through it
Name:  file out igntion housing.jpg
Then you just cut the plug off the factory wiring harness
Name:  factory wiring connector.jpg
And from there you simply match the colored wires with the supplied harness - I found looping the wires through the ignition hole a lot easier for soldering (and make sure you have a high wattage iron - these wires are heavy gauge!) And then one wire to the brake switch
Name:  pull wires through hole to solder.jpg
The company that make these systems is Digital Guard Dawg and I have to give them a lot of credit for coming up with a button solution that worked so well in this truck. At first I was trying to find a solution that would fit in the 2" ignition hole in the dash (picture above) but they found a button (Lexus) that fit right into the factory bezel.
You could use a little tape or adhesive but its pretty much just a nice snug press fit into the bezel and in my opinion it looks great!
Here's their website if anyone is interested - just make sure you get the new Lexus slim button
http://www.digitalguarddawg.com/2GOKEYLESS1.html
100mph is offline
Closed Thread
