Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 01-20-2014, 04:22 PM   #1
Flame Broiled
Flame Broiled's Avatar
Bagged 2012 Crew @ EyeKandyKustoms
So here is our 2012 Siverado Crew Cab. Ekstensive front kit and two link in the rear. KP watts link, and an Accuair for some lifts. In total the truck was lowered 17 inches....
Now to get out there and put her to use....
First step is to remove the bed and any brackets that will be in the way of the step notch
We have now measured and started welding in the notch
Now you can see how much more travel the new system will have.
Flame Broiled is offline   Reply With Quote
Old 01-20-2014, 04:23 PM   #2
Flame Broiled
Re: Bagged 2012 Crew @ EyeKandyKustoms
Of course we need a little ACCUAIR to get things moving
Once the stock springs are out of the way its time to cut off all of the brackets.
Now its time to cut up the bed....
Here is where we stuffed the tank and compressors, still accessible from the bottom if needed.
Old 01-20-2014, 04:24 PM   #3
Flame Broiled
Getting the tubs figured out...
Now the front needs a few more things, battery, air box, fuse panel are all in the way so its time to make so room.
With the stock suspension out of the way, we can now cut out all of the stock arm mounts.
Old 01-20-2014, 04:25 PM   #4
Flame Broiled
With the firewall cut, its time to modify the inner fenders
I think we are headed in the right direction
And here we are ....
Old 01-21-2014, 09:20 AM   #5
Low Elco
Nice clean work. Looks good!
Low Elco is offline   Reply With Quote
Old 01-21-2014, 11:42 AM   #6
Flame Broiled
Thanks, we take pride in our work. And always build things so that it can be taken apart and serviced elsewhere if need be. This truck was a ton of work... but well worth the result. If you want to see more of our work here is our site: www.eyekandykustoms.com
Aaron
Old 01-24-2014, 12:27 PM   #7
Flame Broiled
The Bagged Crew had a friend over for a visit.... a heavily modified Dropped SRT10. These kind of toys make my job fun!!!!
Old 02-22-2014, 12:09 PM   #8
Chvy2NV
really ice job on those inners . truck looks aswesome
Chvy2NV is offline   Reply With Quote
