07-21-2020, 10:53 PM | #1 |
neutral safety switch
After I modified my steering column I am left with no reverse light and neutral safety switch on the column. Did some research and it looks like a transmission mounted switch may work from a 2001 chey 460e trans. i have a 460e trans from a Camaro but it didn't have this switch, has anyone used one of these switches to solve this problem. Thanks Gm #24221125
07-22-2020, 01:24 AM | #2 |
Re: neutral safety switch
You will need to swap out the Manual Shift Shaft for a truck one to run a factory NSS.
Long "truck" shift shaft on the bottom, Short style on top which is what F-body 4L60E's used. Never mind the part number.....I was going the other way putting in a short shaft. You need GM# 24235194. |
07-22-2020, 09:07 AM | #3 |
just watched a utube video on how to do this. Thank you . this is a great help on solving my problem.
One more question. do you know any one that sells these pigtails or know what wires I need to hook up to make reverse lights and netural/park only work to start? Thanks again Last edited by kglowacky; 07-22-2020 at 09:34 AM. |
07-22-2020, 01:23 PM | #4 |
Moderator
Better be quick...this looks like the last one on eBay
https://www.ebay.com/itm/Neutral-Saf....c100677.m4598
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
07-22-2020, 01:44 PM | #5 |
is this switch also do reverse lights i wonder what pigtail does these functions i wont be using all these wires. two for reverse lights and two for park and netrual
07-22-2020, 02:02 PM | #6 | |
Moderator
Find yourself a wiring diagram and follow the colors to the pin outs....
07-22-2020, 03:27 PM | #7 |
Word of Warning
These plugs are secured into the switch with some kind of Super Glue/Gorilla Snot like substance from the factory. In order to remove it or plug it back in, you have to heat it with a heat gun or hair dryer for a minute or so. The glue loosens enough to remove without damaging the plug. (ask me how i know) Do the same to plug back in. I guess it keeps it water tight, but it's a pain in the @$$ I have attached some wiring I found on the internet. Worked well with my 2004 Tahoe donor trans. I used for Neutral Switch/Ign kill as my column didn't have it. It does do reverse lights too but didn't use it for that. If I had time, I would like wire up something to the door locks that would lock the doors in drive and open in park. Maybe when I retire and have more time on my hands. (yeah right)
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project Last edited by Wgesnerjr; 07-22-2020 at 03:44 PM. |
07-22-2020, 04:35 PM | #8 | |
Moderator
My favorite saying now id "You want it by when....hahahaha"
07-22-2020, 05:20 PM | #9 |
looks like everything I need is in the 7 pin. Ground , ign power. Park Neutral and reverse. Perfect. Thanks for the diagram great big help
07-22-2020, 05:40 PM | #10 |
IMPORTANT if you wire this nss make sure to use a relay and only use the park wire to trigger the relay to carry the power for the starter. If u run start right though nss it will smoke it
07-22-2020, 07:30 PM | #11 |
thanks for the info. That makes sense . As far as the reverse will I need a relay also?
07-22-2020, 07:37 PM | #12 | |
Moderator
07-22-2020, 08:03 PM | #13 |
thinking of buying relays with a fuse attached to the relay so all in one assembly
07-24-2020, 03:56 PM | #14 |
for the reverse lights no you dont need a relay the blubs do not draw enough current the starter solionoid pulles like15 amps or so where as 2 1156 blubs are like 2.1amps each so like 4.2 amps is fine ive been running my this way for about 6 months so far no problems
07-24-2020, 04:12 PM | #15 |
thanks
08-07-2020, 08:34 PM | #16 |
I installed the longer shaft today. not a difficult project
08-08-2020, 10:25 AM | #17 |
One option to consider when in this position is a floor shifter with built in reverse and NSS switches. I used an Art Carr Winters shifter. No relays required.
