09-22-2015, 11:59 AM | #1 |
Installed Captains brackets on My '62
Had a bit of interest so I Just thought I'd post some pictures of the progress.
http://67-72chevytrucks.com/vboard/s...d.php?t=675881 1972 C-10 SWB 1962 3/4 ton LWB 2011 GMC Sierra LML Z71 crewcab shortbed Last edited by RKS0069; 09-22-2015 at 01:07 PM. |
09-22-2015, 12:09 PM | #2 |
Re: Installed Captains brackets on My "62
Just A few more
http://67-72chevytrucks.com/vboard/s...d.php?t=675881 1972 C-10 SWB 1962 3/4 ton LWB 2011 GMC Sierra LML Z71 crewcab shortbed |
09-22-2015, 12:35 PM | #3 |
Great job!! I wished the Captain had made these when I did mine !!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
09-22-2015, 12:59 PM | #4 |
Awesome work! Thanks for sharing the info!
Sent Captainfab a message to see if I can get the same parts for my 62. I might have to do something with my steering column/shaft also, I have a later 80's column I will probably use, if possible. What are you using for a column? Did you make your steering shaft? Where did you got the joints for the shaft? Appreciate the info! Pappyx4!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400 1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver John 3:16 |
09-22-2015, 01:42 PM | #5 |
Nice job!!! Captain's parts definitely makes the swap easier.
It only has original paint once |
Thread Tools | |
Display Modes | |
