01-23-2016, 07:44 PM | #1 |
Old member
Vacuum port
Have any of you seen this. I ran across it on FB today for shaved intakes.
This will t off the back port. And give you multiple lines for b as vacuum source or boost source etc. Map sensor runs off a tiny vacuum line so you can hook one straight to the bottom and will work fine. Here is the website. http://www.full-race.com/store/acces...ost-block.html
01-23-2016, 08:19 PM | #2 |
Re: Vacuum port
We used these a lot back when I ran Hondas. We always bought much cheaper ones though. Full race is a great company that puts out a quality product, but in this case half of the price is the sticker on the front. That doesn't do much good when you are trying to hide those lines. I'll probably have Eric do a shaved manifold for me and use something like this.
