07-10-2016, 01:53 PM | #1 |
When 2 becomes 1 (build thread of c10 dually thing)
First step was to disassemble the c/30
"I'm Not Obsessed, I'm An Enthusiast!!! 1981 corvette, always evolving 1986 corvette, brought back from the dead---SOLD 1971 k20 with 1 ton rears, with 69 front clip----SOLD 1979 c10 stepside project, in the works 68+70 dually c10 thing,THE THING!!----SOLD |
07-10-2016, 02:18 PM | #2 |
Re: When 2 becomes 1 (build thread of c10 dually thing)
Then i tore down the engine to get ready for a rebuild. It didnt have an easy life and i found cracks in the lifter valley. So that went in the scrap pile.
07-10-2016, 02:28 PM | #3 |
Cab swap time. Took the cab off the 70 gmc c30 frame, which turned out to be a 67-68 cab anyway, and put it on the c10 short bed frame to start doing the real work. Took some creative rope and pulley work to drag the shell uphill in to the garage.
07-10-2016, 02:38 PM | #4 |
Time to make it lower. 3 inch spindles and 3 inch springs in front, and 5 inch springs in the rear.
07-10-2016, 02:47 PM | #5 |
This is where it gets weird. C-notch. Why not put a dually rear in this truck!! Had to convert it from a leaf spring rear to a coil spring rear.
07-10-2016, 02:55 PM | #6 |
2 more inches of drop and rear shock relocation.
07-10-2016, 03:08 PM | #7 |
Well, if youre doing all this why not convert it to rear disc brakes too............ Turns out they dont make a kit for this rear so ill have to mix and match different parts to make it happen. Mocked it up a few different ways before i found a way i liked that i thought would work well and be easily serviceable.
07-10-2016, 03:21 PM | #8 |
Fabricated panhard bar mount on diff, adjustable panhard bar from an 01 chevy malibu. Rear end and disc brake set up complete with hydrodipped diff cover in a fire skull pattern.
07-10-2016, 03:31 PM | #9 |
Whoops!!! Unforeseen side effect, 16.5 inch wheels dont fit over the calipers. Go to junk yard and get 19.5s to fit. Front brakes redone and all new brake lines from master cylinder out to calipers, including new prop valve.
07-10-2016, 03:52 PM | #10 |
I couldnt help myself, had to put her on the ground and set the body panels on to see what it was looking like.
07-10-2016, 04:08 PM | #11 |
Motor time. 350 4-bolt out of a 1992 k2500 bored .30 over with mild cam. All new from carb to pan. Transmission is a th400 out of a low mileage, wrecked 72 vette, tested good, fluids flushed with new filter and seals. Put the motor in the 6 cylinder position with the 6 cylinder motor stands and still had room for the hei dist near the firewall. I did have to notch the motor stands a little bit to clear the block hugger headers.
07-10-2016, 04:23 PM | #12 |
Motor and trans going in. Mental note, when working around big heavy metal things by yourself, watch fingers or you may pinch finger and then have to drill finger nail to relieve the pressure from blood blister, fun, lol.
07-10-2016, 04:30 PM | #13 |
Now, because the dual wheels narrow the rear end i had to cut approximately 10 inches out of the middle of the bed to have it fit between the tires. I then made a floor out of tiger strand bamboo.
07-10-2016, 04:38 PM | #14 |
Lets make a fuel tank.........out of a keg, and a mount......complete with roll over valve and fuel level sight tube. My wife calls it "the little piggy", not sure why.
07-10-2016, 04:49 PM | #15 |
I ran the exhaust from the headers out through the fender wells to the outside of the frame so i could tuck it up tight for ground clearance in case the truck ever gets bagged. One day walking through a junk yard i and saw some big rig stacks layin on the ground and thought...........why not!!!! Then sent power to the electric fuel pump and fired it up.......she now runs!!!
07-10-2016, 04:56 PM | #16 |
Body panels went on next to start the paint work for the faux patina. 4 different colors, 1 red oxide primer, 2 metallic blue, 3 gray primer, and 4 red.
07-10-2016, 05:05 PM | #17 |
We need an interior. Some sound deadening on the floor, new carpet, bucket seats, and other good stuff.
07-10-2016, 05:11 PM | #18 |
Time to sand off the paint for that found in a field look. I tried to hit all the high points in this thread. There was a lot more stuff done that was kind of boring so i didnt put it in here. Anyway, hope you enjoyed it. Thanks.
07-11-2016, 12:40 AM | #19 |
Crazy ass build man! This thread may interest you, end result is much the same.
http://67-72chevytrucks.com/vboard/s...ighlight=Homer
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
07-11-2016, 01:10 AM | #20 |
Pretty wild looking! I think some type of rear fenders would complete the look though. Just my 2 pennies
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
07-11-2016, 08:38 AM | #21 |
Thanks guys!! Swamp rat, that homer build is pretty cool, and here thought i was the only nut that would make a short bed dually, lol. Tommy, i thought about doing a wide trailer fender, but im taking a step away from it right now to enjoy my other toys for a little while. Maybe in the future ill make something up.
07-11-2016, 09:35 AM | #22 |
Kewl!!!!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-11-2016, 10:04 AM | #23 |
07-11-2016, 08:41 PM | #24 |
Rscb, its great to see another short dually!! If you have any questions send them my way and ill help you as much as i can. Thanks
Thread Tools | |
Display Modes | |
