11-20-2017, 01:03 PM | #1 |
Power Steering k10
Ran across one with a pinched return line, someone force-bent the return line at the box causing the line to be pinched, not fully closed off, just restricted. There was no fluid in it because I guess it all came out the cap.
Swapped the line for a non-kinked one and topped off fluid. Ran truck, stopped truck after a few seconds, topped off again, repeated once more. Turned wheels left and right a few times, no assist. Had no floor jack but was on a smooth surface. Turned truck off, fluid poured out of cap and all over the floor. Chattered a couple of times when turning but never assist. Tried a couple more times, same results. My thoughts were it is a new box AND pump but something wasn't right. Maybe the box wasn't done right or the valve for the pressure side on the pump was messed up. Didn't go any further after that though. Thoughts?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
11-20-2017, 02:03 PM | #2 |
Re: Power Steering k10
That symptom is usually associated with a restricted line. Pressure builds but cannot circulate back to the pump.
11-20-2017, 02:10 PM | #3 |
Yes that is what I thought and I remedied the kink in the line, but it still spit fluid out after that.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC Last edited by demian5; 11-20-2017 at 05:45 PM. |
11-20-2017, 07:07 PM | #4 |
I fought a similar situation with my build a few months back. With wheels off ground, I would get a little assist when turning right but nothing to the left and the pump chattered like it was going to explode. When I turned off engine, fluid would boil out of the pump. Same as you I had new steering box and pump. What I did was (tires off ground) first, turn wheel right to left with engine off. I went from lock to lock with engine off. Then I let truck run without trying to turn for a few minutes, then I very slowly turned steering to right to the lock, then back to left. If it fought me, I would let it run at idle without trying to turn for a couple of minutes. I did this for a few cycles and the steering got better each time. Now it turns with no effort with tires on ground. I think it took all this to get all the air out and bled 100%.
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
