Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 02-13-2017, 10:48 PM   #1
chrismoore701
chrismoore701's Avatar
Can bondo go bad?
I have a gallon of evercoat liteweight filler and I keep it in the house. Mixed up a batch tonight and it gets hot and starts to harden but I can still dig in it with my finger nail after 30-45 min. Third batch I mixed and the same thing for all batches. It is about 2 years old. But still nice and creamy.
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 02-14-2017, 12:11 AM   #2
Foot Stomper
Foot Stomper's Avatar
Re: Can bondo go bad?
2 years is really young filler. It tends to get impossible to stir when it's too old. The hardener is more likely to go bad first. It needs to be kneaded (no pun intended). If it was watery and rather unhealthy looking it's your culprit. Get new hardener and try again.
Or you simply undercatalyzed it...
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 02-14-2017, 08:41 AM   #3
chrismoore701
That was the first thing I did was get a new tube of hardener. I also put the bondo on my paint shaker, helps make it more creamy. I am sure I am mixing enough hardener in with it, but it seems like that may be the issue. It starts to firm up in about 10 min, but just does not get hard.
Chris
Old 02-14-2017, 11:10 AM   #4
Foot Stomper
Never put bondo on a paint shaker because it fills it with air bubbles causing pin holes. The manufacturing process goes thru great lengths to avoid mixing in air so paint shaker is not recommended at all.
Most folks under catalyze filler and on a rare occasion over catalyze it. They all require 2-3% which seems like too much when you see it. Put a blob of filler on your mixing board and then make 3/4 of hot cross bun icing pattern with the hardener and you'll be close.
Should be ready to sand in 30 minutes if your shop is 70 degrees.
Old 02-14-2017, 12:25 PM   #5
MARTINSR
MARTINSR's Avatar
YES it can go bad. And how old it is isn't the biggest factor, did it get any air is the biggest. If the lid isn't tight and proper it doesn't take long at all for it to dry out.
I have to tell you, I have a bunch of stuff at home, gallons of clear, bondo, paint, primer that I got when I was a paint rep. This is now a number of years ago and every time I go to grab one I think about it, toss it and buy new. It's just not worth it!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 02-14-2017, 03:39 PM   #6
chrismoore701
Lid was tight, it is still creamy, not thick. Stored in the house.
Chris
Old 02-14-2017, 10:21 PM   #7
68c10airstream
68c10airstream's Avatar
Hi Chris, I priced the evercoat body filler last year and it was about $20.00. If this is still true is it worth it to take a chance on it for $20.00? Your time and quality of the job at hand hangs in the balance. Body shops here are in the $65.00 per hour rate. So the first 1/2 hour you saved yourself working on your project justifies a fresh evercoat gallon of filler!!
I question myself all the time working on my house from hell, quality or cheaper choices and i still go the costlier route. I hate doing things twice, good luck!
68c10airstream is offline   Reply With Quote
Old 02-15-2017, 08:29 AM   #8
chrismoore701
I agree, just not happy about it. it is about 75% full and I hate tossing it. but your right
Chris
Old 02-15-2017, 09:34 AM   #9
cg285
years ago an acquaintance over "hardnered" a large batch of plastic filler and 2 weeks later it was still soft. he had to dig it all out.
cg285 is offline   Reply With Quote
Old 02-15-2017, 10:34 AM   #10
Foot Stomper
I'm curious if the new can turns out to be the same as the old one.
My bet is it will be if the same hardener and same amount used.
My career as a manufacturer's representative for a filler and finishing glaze manufacturer, I am not concerned about the age of the filler as long as it's still creamy and the resins have been mixed in. By far the biggest challenge with filler is the hardener. Sometimes it will sour and/or an incorrect amount is used. CG285 brings up a good pint that over catalyzation can also be detrimental although most folks will tend to unde catalyze..but not all.
OP ChrisMoore701 please post a picture of your next few batches showing the amount of hardener you have used before mixing it in as this will be very helpful in assisting you.
Old 02-15-2017, 10:58 AM   #11
chrismoore701
Will do, I just bought a new tube of hardner, so I know that is good. Will try to get out there tonight
Chris
Old 02-16-2017, 08:24 AM   #12
chrismoore701
Still does not seem to set up
Chris
Old 02-16-2017, 09:40 AM   #13
Foot Stomper
When you sand it does it gum up your paper? I'm curious about your concern it's not set up. It won't be like concrete when set up and should be soft enough to fingernail scratch.
The amount of hardener looks a touch too much so id suggest cutting it back by about 1\3. Too much hardener can cause it to stay soft (among other negatives) but I'm not sure you've pushed it that far over its limit.
Old 02-18-2017, 07:27 AM   #14
Dayton601
Dayton601's Avatar
I'd say to much hardener,
Dayton601 is offline   Reply With Quote
Old 02-28-2017, 03:06 PM   #15
El Dorado Jim
It starts to firm up in about 10 min, but just does not get hard. may need viagra!!! sorry, couldn't resist
El Dorado Jim is offline   Reply With Quote
