Old 03-17-2017, 05:40 PM   #1
rharris
rharris's Avatar
Max backspacing 71/72 C10
If anyone has any experience with the following I would greatly appreciate it before sending the wheels off to the paint shop.
I ordered a set of 15x8 wheel vintique 62 steelies for my 72 C. Backspacking is 4.25" and offset is -6mm. In a quick no tire fit the rear seem fine. However, the front look like it may be too tight when I get the tire on. I have a set of 275/60's that are on it all four corners with aluminum 3 7/8 backspacing with no issues. Truck is currently stock, but may get a set of 2.5" drop spindles.
rharris is offline   Reply With Quote
Old 03-17-2017, 06:47 PM   #2
diggerbob
Re: Max backspacing 71/72 C10
I cant answer your question but as someone who has wheel vintique ralleys on my 70, I would advise to to have the rims checked for lateral runout before you mount them. They wont take them back if they have had a tire mounted. One of mine had a runout of 0.041" and shook my truck pretty bad at highway speed. I wouldnt accept more than 0.025" lateral runout.
diggerbob is offline   Reply With Quote
Old 03-18-2017, 08:24 AM   #3
rharris
rharris's Avatar
thanks for the info. I had not thought about that. I never had an issue before.
Old 04-08-2017, 11:43 AM   #4
rharris
rharris's Avatar
In case anyone else was wondering, the 4.25" backspacing on the standard 15x8 wheel vintique steelies fit with 275/60/15. It is currently stock height. The wheels balanced with no issues. I was concerned the tires might rub on the upper control arm. So far so good.
72 Cheyenne Super C10 SWB
71 K10 LWB (Parts Truck)
2001 Silverado 1500HD Crew
2007 Silverado Classic 2500HD Crew Duramax (Hers)
Old 04-08-2017, 12:35 PM   #5
lolife99
Old Member
lolife99's Avatar
Thanks for the follow up info.
Keith
Convert to disc brakes.
WTB: Radio Delete Plates and clips.
lolife99 is online now   Reply With Quote
Old 04-08-2017, 12:52 PM   #6
rharris
rharris's Avatar
Pictures in thread below.
http://www.67-72chevytrucks.com/vboa...d.php?t=734944
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
