Old 10-23-2018, 02:23 PM   #1
FLATFENDER54
Work begins on the 1962 C10 4WD k10
My 70 year old father bought this about ten years ago with intentions of restoring it. When he was young, one of his friends had a 62 4x4. My father, as he got older, had always wanted to get one for himself. This truck has basically sat around for the last ten years and he had given up on the restoration. Well about 6 months ago my 14 year old son asked grandpa if they could work on the truck together and get it running (maybe sell it then). Well he said yes and they decided not to do a restoration but instead just make it look nice, be safe and look more or less original to the casual observer.
The ideas of selling it has passed and 3 generations are now working on the truck with the goal of having it ready for my son to occasionally drive when he gets his license in 2 years.
I've been lurking on this site for a while and it has been very helpful and Ive even ordered a few things from Captain Fab (who I highly recommend)
Anyways I'm sure gonna have a lot of questions and need Ideas as this goes on.
Thanks. Jeff
FLATFENDER54 is offline   Reply With Quote
Old 10-23-2018, 02:32 PM   #2
61K10
61K10's Avatar
Re: Work begins on the 1962 C10 4WD
Welcome to the forum! and another k truck is a delight to see. Post up some pics so we can see or better yet start a build thread. have fun-----------
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-23-2018, 02:33 PM   #3
FLATFENDER54
Thanks I will. Trying to figure it out right now.
Old 10-23-2018, 02:49 PM   #4
FLATFENDER54
Front view. From what I think I learned it has a 60 Grill, and 60 or 61 Hood.
Doesn't look like it was ever wrecked and probably was well taken care for the first half of its life (not its entire life though) haha
It is a 283 with a manual 4 speed on the floor. Still has the generator. Been swapped over to an aluminum intake and a 4 barrel
Old 10-23-2018, 03:05 PM   #5
61K10
61K10's Avatar
Nice tk and it has a 60 hood. The inserts are different on a 61.
1961 chevy K10
Old 10-23-2018, 03:17 PM   #6
FLATFENDER54
Your truck looks very nice. Hopefully "grandpas" truck will look just as nice.
His plan is the original orange it had on it. With possibly a white top and the door inserts painted white against the orange interior. He is still deciding on steel wheels or some type of aluminum. I like the 2500hd 6" wide factory 16" aluminum wheel and trying to talk him into them. Tall skinny tires. It had 35" tires on it when we got it but they were just too tall for him.
Old 10-23-2018, 03:25 PM   #7
FLATFENDER54
We found a set of 1973 axles with disc brakes. 8 lug Dana 44 and a 14 bolt rear. The rear bolted right in. The front I had to cut off the old shock mounts and move them onto the Dana 44
Pictured below are the original axles
Old 10-23-2018, 03:38 PM   #8
FLATFENDER54
Axles in place with temporary dodge wheels and tires we scored for 50 bucks
content://media/external/file/7278
Old 10-23-2018, 03:46 PM   #9
FLATFENDER54
Power steering was next on the agenda. It turned out to be a major pain by the time is was done. Thanks to Captain Fab the steering box mounting was easy and his slide on steering shaft made that portion simple also
Old 10-23-2018, 03:57 PM   #10
FLATFENDER54
Getting the power steering pump mounted on the engine was another story. Major PITA! Our truck had the front horseshoe engine mount with the front crossmember in the way (no side motor mounts) I switched over to an aftermarket crossmember with side motor mounts. Welded it up and then bolted it in-between the frame rails and to the side motor mounts. Then I removed the horseshoe mount at the front. We left the front crossmember in because its not in the way now. Plus I'm sure it gives extra strength to the steering gear box mount (its partly behind it) Also had to get a 3 groove crank pulley, 2 groove water pump pulley and a 2 groove alternator pulley for the generator. I could not figure out a way to get the clearance for the power steering pump belt to run around it alone.
Everything is new "1973" on the steering except the power steering pump. Went with a 1975 pump so could could use a press on pulley. This way we could have a little wiggle room on the pulley alignment and location. Was also able to use the hoses for a 1973. Just had to bend the return line carefully at the gear box. I will clean up the fender hole better later
Old 10-23-2018, 04:10 PM   #11
FLATFENDER54
Working on the brakes now. Got a manual trans power booster bracket from Captain Fab. It's a tight fit but went in like it supposed to. 9" power booster brake kit for drum disc is in. Everything needs hooked up still though. I had a simple surgery and can't strain for a couple weeks but we have about 2 years to finish.
That's a new Holley 650 on there. Got a real good deal on it so just removed the old and in with the new
Old 10-23-2018, 04:18 PM   #12
FLATFENDER54
Found a 88 to 98 seat on Craigslist for 60 bucks
. They really do bolt in to existing seat holes in the floorboards in the front. Will need to drill for the back 2. Feels much more comfortable. It will be reupholstered more appropriately in future
Old 10-23-2018, 04:29 PM   #13
FLATFENDER54
More pics
Old 10-23-2018, 04:31 PM   #14
FLATFENDER54
More
Old 10-23-2018, 04:39 PM   #15
FLATFENDER54
More
Old 10-23-2018, 04:44 PM   #16
FLATFENDER54
More
Old 10-23-2018, 04:51 PM   #17
FLATFENDER54
Found 2 replacement doors a couple months apart . 100 bucks each
Old 10-23-2018, 04:55 PM   #18
FLATFENDER54
The floorboards are real good shape. The doors are pretty much shot and the rockers are bad. Cab corners are good.
Old 10-23-2018, 04:59 PM   #19
FLATFENDER54
We have the long bed that goes with it. Its in decent shape with no floor in it. Ill have to add pics later it is not inside the shop
Old 10-23-2018, 05:04 PM   #20
FLATFENDER54
I have a few questions if anybody has an answer for me?
Will the front shackle rebuild kit for the later trucks work for the 1962 I have? They look almost the same?
My VIN number and title says its a C10 but its a 4wd (no way this was converted this completely and original by a previous owner) Is that common? A 4wd C10?
And do the hood inserts / scoops just let the weather into the engine bay or is the truck missing something?
Old 10-24-2018, 12:00 AM   #21
Captainfab
60-66 Nut
Thanks for the good words about me and my products
Just what years are you referring to as 'later trucks'?
It sounds to me like the cab was replaced at some time. The frame is drfinitely a K series frame. Compare the cab VIN to the frame VIN.
Sorry I can't help with the hood grills, I've only had a couple '60-'61 hoods in my time and I don't remember what was on the inside.
Old 10-24-2018, 02:01 AM   #22
ApacheNick
From what I can tell comparing your pics to my 61 4x4, your frame is a 60-62 4x4 frame. As Captainfab said, your cab was probably replaced at some point.
As far as I know, there's nothing that blocks off the park/signal light inserts in the hood.
Nick
1961 Apache short stepside 4X4 SBW 348/4 speed
1960 Apache C-20 long fleet custom cab BBW 283/4 Speed
1967 rust bucket Olds Cutlass with a 455
1972 GMC K-15 350/4 speed long fleet
ApacheNick is offline   Reply With Quote
Old 10-24-2018, 08:49 AM   #23
FLATFENDER54
Do the 2wd cabs also have the high hump removeable trans cover?
Old 10-24-2018, 09:06 AM   #24
FLATFENDER54
Sorry I can't help with the hood grills, e.
So no C10's were 4wd in 1962? Where is the VIN at on the frame? Any other diffences in the cab or way to tell what year? The hood and grill are a 60. Maybe its a 60 cab?
Old 10-24-2018, 10:08 AM   #25
66K20
66K20's Avatar
C indicates 2wd chassis
K indicates 4wd chassis
Brett | 1966 K20 - 292/SM420/T221
66K20 is offline   Reply With Quote
