Old 03-03-2019, 10:07 PM   #1
Hotcorner
Hotcorner's Avatar
Transfer Case Shifter Pivot Bushing
Anyone have an idea for where to find the bushing kit for that? T-221.
1969 GMC K25
2007 Chevy 2500HD Classic Duramax
1999 Tahoe 2DR 4WD Base Model 5.7l
Hotcorner is offline   Reply With Quote
Old 03-04-2019, 02:15 PM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Transfer Case Shifter Pivot Bushing
If its nylon i could make you one on the lathe.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 03-04-2019, 05:12 PM   #3
OldCreek
OldCreek's Avatar
I think I did something similar with a copper bushing, as recommended by someone on this site.
Best of luck.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 03-04-2019, 05:39 PM   #4
renegade6
It looks a lot like a clutch or brake pedal bushing. Dorman may make a universal one that will work.
https://www.amazon.com/Dorman-74016-.../dp/B003GBIFKW
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 03-04-2019, 09:22 PM   #5
mongocanfly
Post Whore
mongocanfly's Avatar
I agree with renegade..i just cleaned up and lubed my clutch/brake pedal bushings...they look identical to what I see in your pic...
are those worn out?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-04-2019, 09:58 PM   #6
Hotcorner
Hotcorner's Avatar
That’s EXACTLY what they look like. There’s a steel sleeve over the pivot bolt with one of those on each side. Thanks!
1969 GMC K25
Old 03-04-2019, 10:01 PM   #7
Hotcorner
Hotcorner's Avatar
are those worn out?
There’s a fair amount of slop in the pivot. Hope these will tighten it up. Having trouble getting into 2HI. Adjusting the rod clevises and replacing the see-saw bar, but thought a tighter shifter would help too.
1969 GMC K25
