01-17-2020, 07:48 PM | #1 |
Transmission swap question
I have a 72 C20 pickup with a th350. I want to change it to a 700r4 and want to know if anyone knows where i can get the new crossmember for it.
01-17-2020, 09:30 PM | #2 |
Its a Truck Thing......
Re: Transmission swap question
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
01-18-2020, 11:27 AM | #3 |
Old member
No need for a new crossmember it will work fine on your 350 but you will need the rubber mount for it. That it. I just did a 700-R4 in my 68. Slide the crossmember back and drilled 2 holes.
01-18-2020, 11:34 AM | #4 |
Andy,
Post a pic of how it looks to access the rear pan bolts with a stock crossmember. Smitty
01-18-2020, 10:36 PM | #5 |
Old member
I will try and remember to do this tomorrow. From what I remember it's very tight but doable. I used this same setup on the 71 C 10 when I did the 700-R4 in it.
01-20-2020, 09:22 AM | #6 |
When I dis mine I trimmed the small horizontal flange on the front of the crossmember. Then added a plate inside the vertical to strengthen it. Gives needed space for access to rear pan bolts. Although the gusset probably wasn’t necessary. 15+ yrs. no issues.
Smitty '71 Short Fleetside Spring Valley, Ca. |
