Old 01-27-2020, 06:31 PM   #1
truckin 79
Changing rear end fluid posi or not
Did a 79 1/2 ever come with a posi rear end? I need to change gasket and fluid but did not know if I needed to add special posi fluid. I have a big oil sludge hanging under rear end and so I think it is leaking gear oil and needs changed.
thanks
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 01-27-2020, 07:45 PM   #2
Matt Man
Matt Man's Avatar
Re: Changing rear end fluid posi or not
Could have came with a g80 which required the additive. Once you have the cover off you will know if it has one or not.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 01-27-2020, 10:30 PM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
Does it still have the spid in the glove box?...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-28-2020, 07:59 AM   #4
cadillac_al
I always used Carquest gear oil that works in either one.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 01-29-2020, 11:02 AM   #5
CSHADES
CSHADES's Avatar
We started using the Ford posi additive to anything with posi traction.
CSHADES is offline   Reply With Quote
Old 01-29-2020, 12:27 PM   #6
truckin 79
I do not have spid had to change glove box doors as hinge was gone. I just assumed most later trucks with be a one legger and no posi. I heard that if you go with Synthetic a person does not need to posi additive. Is this true?
Old 01-29-2020, 01:30 PM   #7
Matt Man
Matt Man's Avatar
No synthetic fluid does not replace the posi additive.
This is a open rear end:
This is a g80 rear end:
The g80 in the half ton axles (12 bolt, 10 bolt) are not very good I would be surprised that it would still be in there. My 81 came with one but when I got the truck it was not there, just had a open diff.
Thread Tools
Display Modes
