02-16-2020, 11:27 PM | #1 |
70 C10 LSX swap question
Hello everyone,
I have a 70 short bed that I recently put a 5.3 Vortec motor in. I bought a new harness and had the computer flashed. I made sure all connections are plugged in and lines are all tight. I start it and it immediately revs up really high and back fires. Then it goes to normal idle for about a minute then revs up again and just stays there. I checked all vacume lines and there are no leaks. My harness is hooked up to a good ground. I did notice that the Evap Solenoid is missing and there is just a hole in it’s place. Could that be the cause of it? Any advice is greatly appreciated as this is my first swap. Thank you |
02-18-2020, 04:17 PM | #2 |
Fabricate till you "puke"
Re: 70 C10 LSX swap question
Some of the trucks , did not have that evap solenoid...(tin cup that pushed in with a bolt to hold it down. Get your best bud , or wifey out & stick a thumb over the hole.....fire it up & see if that takes care of the problem Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-18-2020, 05:12 PM | #3 |
I'd second that. A hole like that acts like a vacuum leak. If you're working by yourself figure out what makes a good substitute for a thumb. Rubber plug, big piece of duct tape, or whatever.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
Thread Tools | |
Display Modes | |
