Old 07-10-2020, 10:02 PM   #1
GA Cowboy
GA Cowboy's Avatar
Opening under dash
Can anyone tell me what this opening under the control box? under the dash is? The AC is blowing out about 60 degrees but 40 on this vent. Thanks.
1972 GMC 1500
1/2 Ton, LWB, Fleetside, 350, Automatic, 3rd Owner.
GA Cowboy is offline   Reply With Quote
Old 07-10-2020, 10:14 PM   #2
Andy4639
Old member
Andy4639's Avatar
Question Re: Opening under dash
I've always wondered what it was for also. I always figured it was for your feet. I would like to know the reason for it also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-11-2020, 12:02 AM   #3
toolboxchev
If it is blowing that cold I would venture to say its there to prevent the unit from freezing up.
Common sense, SWAG, or corrected error on part of GM.
toolboxchev is offline   Reply With Quote
Old 07-11-2020, 12:07 AM   #4
FirstOwner69
FirstOwner69's Avatar
I always figured it is for the feet if desired. You should be able to shut it.
Jim
FirstOwner69 is offline   Reply With Quote
Old 07-11-2020, 07:04 AM   #5
sick472
sick472's Avatar
The only way mine would blow 40 degrees would be in the dead of winter before the engine wanted up...ac delete here.
I think it's more of a winter time heat option to help warm or dry wet feet. It pops shut with a little pressure.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 07-11-2020, 08:41 AM   #6
Mike C
Mike C's Avatar
It's just an additional vent and clearly you are getting heat polution in your duct system from somewhere else. If it is blowing 40 out of there then that is the temp your ac is cooling to. You need to check flapper doors, heater shut off valve, etc. and you should be able to get 40 degree air from all the vents.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
